Author Topic: CR750 replica build  (Read 34176 times)
Offline Napoleonb
Re: CR750 replica build
« Reply #165 on: October 24, 2019, 05:29:11 PM »
Nice find on that hub!
Offline CR21
« Reply #166 on: October 24, 2019, 09:01:31 PM »
Cheers Nap!
« Reply #167 on: October 24, 2019, 10:02:23 PM »
Great detail Scott - but you know that already! Having gone through a compromise replica build, really appreciate your build
Offline CR21
« Reply #168 on: October 24, 2019, 11:31:31 PM »
Thanks Phil. Your build is far from a compromise. It is a cracker of a bike.
A few more frame jobs completed today!
A couple of options for mounting the oil cooler on the CR750, a bracket was available for the kit bikes which provided the offset holes for the cooler. I have not seen the frame area on a factory bike, however my suspicion is that they may have mirrored the horn bracket to accommodate the cooler...
Folded up a mirror image bracket:
Welded on some flanged nuts:
Trimmed back and jigged up:
Welded on and ready for final fettling:
Still a fair few things on the frame to-do list!
- Rear hoop and cross brace to accept catch tank
- Steering damper mount
- Lower oil-tank mounts
- Lower fairing mounting plates
- Brake stops, and welding of the cable bushes
- Remove chain guard mountings from the swinging arm
- Many other small details!
Cheers,
CR21
« Reply #169 on: October 25, 2019, 10:17:35 PM »
Thats exactly what I did Scott
Offline CR21
« Reply #170 on: October 25, 2019, 10:40:53 PM »
Hi Phil,
Hope it turned out ok? I think a few people have done it, how accurate it is to an original I don't know but I think it will be in-keeping once it is all painted up.
Cheers,
CR21
Offline CR21
« Reply #171 on: October 25, 2019, 11:43:39 PM »
A little progress from today:
Oiltank
Oiltank brackets tacked on, ready to check chain-clearance etc:
Exhausts
The CR75O exhausts are a 'big' part of the appearance of the machine, and something that I would like to get looking tidy.
I believe on the original bikes each exhaust pipe was made of two pressings, which were then welded or seam rolled together. This left the appearance of a seam running at the top and bottom of the pipe. The headers were formed separately and were welded or clamped to the pipes.
Although the shape profile could be achieved with rolling or even sand bending rolled cones, the appearance of a seam is hard to achieve
The obvious next step was to give it a go...
So a good chunk of time was spent today trying out hydroforming! Something that I have watched many videos on and read about but never tried.
Quick trip out to pick up various fittings to allow the cheapo pressure washer to be hooked up to the sheetmetal assembly, tapped hole in the blanking plug for bleeding air out of the system:
The hardest part of the CR exhaust shape is the curve, so the first flat pattern was knocked up to test the curve profile section. Complete guesswork for the angle and diameter (scaled off of photographs) at this stage and purely for experimentation:
Seamed together and valve welded in:
Hooked up, with a little safety cage!
Pumped up around 400psi
Happy for a first attempt, but very wavy edges and some buckling  :-\
The pattern next to the product:
Round two!
Stainless sheet, smoothed pattern shape, special attention on matching the two halves and having smoother curves:
The latest attempt above the first attempt and pattern:
What I have learnt about hydroforming today is that the pattern, weld penetration and consistency are key to repeatability.
And that it is with a bit more experimentation I could possibly achieve what I am after...
I think I am going to purchase off the shelf header pipes, however I may experiment with another process I have been wanting to play with for a while which is sand-bending...
Cheers,
CR21
« Reply #172 on: October 26, 2019, 12:37:38 PM »
Wow, fascinating work. I like to have a go at most things buts hats off to you for trying hydroforming with that pressure and being successful.
Great thread, looking forward to the next installment and photos.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
« Reply #173 on: October 26, 2019, 02:45:24 PM »
I think I've mentioned it to you before Scott, but when trying to calculate the visual up sweep on the pipes, don't forget that in the picture of Dick Mann on the bike, his weight is on the bike and hence the swing arm is pushed up. I positioned mine relative to the rear wheel spindle as a reference the the picture- but the bike was on the 'A' frame stand when I welded the exhausts together - with no weight on it (which looked the right up sweep). But when everything was assembled and I sat on the bike, the exhausts are lower than I wanted. Just a thought!
Online AshimotoK0
« Reply #174 on: October 28, 2019, 10:58:49 AM »
Looking fantastic... talked to a guy yesterday at Newark who I get parts from and he told me he just recently sold a CR rear hub for £350 to somebody. Thought it might have been you Scott but seems not.
His was from the estate of Alf Briggs who was Honda UK's Service Manager from the very early 1960's and held all of the race parts at one time. Alf was a close friend of Mr. Honda and when they pulled out of racing  Alf was allowed to keep all of the spares I believe.
Offline CR21
« Reply #175 on: November 15, 2019, 02:54:00 PM »
Hi Laverda, it was pretty simple to be honest but I can't call the result a success yet! I think once I have developed the pattern, along with some very consistent welding it will be more successful. Learnt a lot from the trial parts.
Phil - I remember you mentioning this - thanks for reminding me! So many details on these bikes.
Hi Ash, I think I know who you are talking about. pm sent for further discussion.
Rear Hub
A little more progress on the replica rear TLS hub.
The CAD assembly is coming along, still a lot of detail to add!
Cheers,
RD17
Offline CR21
« Reply #176 on: March 10, 2020, 03:59:22 PM »
Hi all,
Small and slow steps on this projects due to other projects consuming heaps of my time!
Anyway a tiny update! The fork bottoms are back from the foundry. How just to figure out the machining techniques and cartridge details  ;)
An original image for reference:
And the cast blanks!
H2 Eric did a wonderful job of his forks, I have asked him for a little more info.
Cheers,
CR21
Offline Napoleonb
« Reply #177 on: March 11, 2020, 10:08:18 PM »
Looking good!
