Author Topic: RD125  (Read 9564 times)
Offline ffoy
Re: RD125
« Reply #45 on: March 27, 2017, 12:48:22 AM »
Thanks for all the replies re forks guys. Will send my bent ones off to the place in Sandbach
Re: RD125
« Reply #46 on: March 27, 2017, 01:41:05 PM »
paint work starting to come together,
 decals need applying,the fork ears still need a little work,but otherwise I'm happy,
one picture is how it should look !!!
other is how it is coming on
http://classic-motorbikes.net/yamaha-rd125b-road-test/
Offline ffoy
Re: RD125
« Reply #47 on: March 27, 2017, 01:58:29 PM »
So you're going for the A 'stripe' decals rather than the pre-A 'swoosh' ones. Probably a wise choice as the sidepanel/oil-tank decals are available for the A but on the pre-A it was a chromed plastic 125 badge and cannot get them anywhere
Re: RD125
« Reply #48 on: March 31, 2017, 07:21:23 PM »
 got the tinware back today,really nice finish,fitted new Tap,oil sight glass,and various little odds and sods,
Offline ffoy
Re: RD125
« Reply #49 on: March 31, 2017, 10:37:08 PM »
Excellent. Regarding the oil-glass. It's unlikely you'll be removing/refitting one again but best way to get them out is to push them in then fish them out filler-neck.
Seems a strange approach but they're almost impossible to lever out even if you're not fussed about damaging the seal
« Last Edit: March 31, 2017, 11:51:50 PM by ffoy »
Re: RD125
« Reply #50 on: March 31, 2017, 10:54:34 PM »
thanks for that,
  that is how a removed it,cutting the outer lip off,and pushing through,before taking it for painting,but getting the new one in was hard work !!!,I had to clean some of the new paint away before it would fit,
 thanks for your nice comments
Re: RD125
« Reply #51 on: April 01, 2017, 04:19:21 PM »
nice sunny day,
  a little pottering in the garage
Re: RD125
« Reply #52 on: April 01, 2017, 05:32:42 PM »
Is that the same as the RD 200 with the mechanical advance visible outside the generator, If so take a lot of time getting the timing correct with a DTI and a tool to hold the advance open, once watched a boss of mine bump start an RD 200 the put his helmet on to road test it for a fault whilst I kept it running the ride off backwards when he put it in gear as it had started backwards!! Lots of laughs and encouragement on that one.
If you want to email me direct(addy in profile) I will send you a pic of the special tool that will take about 5 mins to make
Re: RD125
« Reply #53 on: April 01, 2017, 06:29:11 PM »
thanks Bryan,
 the 200 had an advance mech because of the electric start,a sort of Dynastart gadget ,all the others from 100cc up to 400cc used
static timing using a dial gauge,  1.8mm BTDC,or with the new fuel ,suggested 1.7mm
 I have a Dial gauge,like going back to the dark ages with points again -))))))
Re: RD125
« Reply #54 on: April 01, 2017, 11:58:41 PM »
Nowt wrong with points mate, just spend a lot of time getting the gap correct and the timing spot on and you will be fine
Offline MarkCR750
Re: RD125
« Reply #55 on: April 17, 2017, 05:19:07 PM »
Any more progress John?
Suzuki GT250A (Nostalgia)
Ducati 900SS (Soul & Speed)
Thruxton 1200 (suits me)
Sir J.Stewart.
Re: RD125
« Reply #56 on: April 17, 2017, 05:53:47 PM »
  a little more,
  got the tinware back,
 assembles the exhausts,clocks,electrics,just awaiting a decent throttle cable
Offline MarkCR750
Re: RD125
« Reply #57 on: April 18, 2017, 08:31:53 PM »
Looking good John, it will be great fun to ride, like an FS1E on steroids!
Sir J.Stewart.
Re: RD125
« Reply #58 on: April 18, 2017, 09:13:49 PM »
  I used to have a YAS1 twin, a forerunner of the RD,and a YDS7 ,a bigger brother ,before I started owning Hondas
Re: RD125
« Reply #59 on: April 22, 2017, 04:02:02 PM »
been playing in the garage today,
I have been having issues with the throttle cable,it is one cable from twistgrip to a splitter,then 2 carb and 1 oilpump cable,try as I might
I could not get this to work properly,each time both the carb cables detached inside the splitter unit,
 the splitter outer tube,and nylon inner have some playso I surmizzed the inner was tiltingand the out flexing allowing both cable nipples to pop out !!
so decided to make a new inner unit,using nylon bar,
check the pics,and yes,it works great !!
