Author Topic: Electronic ignition  (Read 5547 times)
Offline masonmart
Electronic ignition
« on: May 25, 2016, 01:21:08 PM »
Can anybody recommend a good EI system for a CB500.
MM
Dresda CB500-4, 605 cc
CB-77, 350 cc
1968 Bonneville
1976 Thruxton Velocette
1974 Kawasaki Avenger
1997 VFR 750
Re: Electronic ignition
« Reply #1 on: May 25, 2016, 02:14:37 PM »
Boyer Bransden every time. Bit of a faff to fit but well worth it. Avoid the cheaper ones as you'll end up at the side of the road scratching your head.
Sent from my Nexus 6 using Tapatalk
Offline JustcallmeMrT
« Reply #2 on: May 25, 2016, 02:22:40 PM »
I installed a dyna system and accidentally fried it by leaving the key on for awhile before starting the bike - apparently if you don't start the bike the unit wont discharge and nasty things happen - there is a risk if on for any more than 10 seconds... really wish they would have said that in the manual....
Sent from my SM-N9005 using Tapatalk
Offline masonmart
« Reply #3 on: May 25, 2016, 03:00:05 PM »
How about the Units that David Silver sells at around £100?
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
« Reply #4 on: May 25, 2016, 03:07:48 PM »
I know Norniron got one from DSS and said it was shite.
« Reply #5 on: May 25, 2016, 03:21:12 PM »
Quote
Could you be a bit more specific? Cheaper ones of Boyer & Bransden you mean?
« Reply #6 on: May 25, 2016, 04:43:28 PM »
Sorry I should have said, stick with Boyer and avoid the cheapies like the dss unit or the other eBay offerings. You only want to do this once so pay a bit more for the Boyer unit. There's people on here that fitted Boyer 30 plus years ago and never touched it since. Highly recommended.
« Reply #7 on: May 25, 2016, 06:01:44 PM »
Quote
Could you be a bit more specific? Now your comment has much of the 'Now that I've spent all that money, it must be good bias'. What other eBay offerings do you have experience with?
Heck, I've built my own (for less than € 18,-) and it has worked perfectly for 15 years till I tore some wires myself by mistake. I'll repair it soon as all components are still OK. There's nothing special about EI. If you look closely at a contactbreaker it must be more expensive to manufacture  than an EI.
« Last Edit: May 25, 2016, 06:15:08 PM by deltarider »
« Reply #8 on: May 25, 2016, 06:14:04 PM »
Quote
Heck, I've built my own (for less than € 20,-) and it has worked perfectly.
Not correct DeltaRider, I don't care what it costs. Boyer has a reputation in the EI game second to non. This is a topic that has been aired again and again on this forum and on the internet generally and the opinion is usually buy Boyer. The online forums are littered with tales of DynaS failures. Already on this short thread Dyna and the DSS systems have been slated. Just trying to help a forum member as not everyone is capable of building there own.
On a more positive note. The Boyer system not only does away with the points, but the mechanical advancer as well. Thus becoming totally electronic. I have it fitted to two of my bikes, and would definitely recommend them. But Deltarider is absolutely correct in that it is an expensive system especially if you use the matched mini coils as I have done.
Hope some of this has assisted you Masonmart.
« Last Edit: May 25, 2016, 07:00:56 PM by royhall »
Offline masonmart
« Reply #9 on: May 25, 2016, 08:06:48 PM »
To say that the DSS units are crap is a bit of a sweeping statement without saying why. I guess that the main reason is that they use the existing advance and retard?
Just another question. How much improvement does EI make over points? For an engine that hasn't run for 40 years and has just been rebuilt may it be better running it initially on points?
« Last Edit: May 25, 2016, 08:37:14 PM by masonmart »
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
Offline Norniron
« Reply #10 on: May 25, 2016, 10:14:22 PM »
It was indeed Pure SHITE Graham
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline Norniron
« Reply #11 on: May 25, 2016, 10:21:01 PM »
Doesnt Hondaman on sohc.net do a electronic ignition for the 500/550 that incorporates the original points?
1977 400 cafe
1972 500/4
2013 triumph STR675
« Reply #12 on: May 25, 2016, 10:23:55 PM »
 I have used Boyer since about 1978 ish,
  can't say better than that,
expensive ???   it cost me less then £30,
 it may have gone up since then,but I am very happy with it
« Reply #13 on: May 25, 2016, 10:31:42 PM »
Why don't you say it as it is David ;D ;D
« Reply #14 on: May 26, 2016, 06:55:14 AM »
Have a look at this link:
http://www.sohc.co.uk/index.php/topic,9489.msg66492.html#msg66492
Boyer don't actually list a system on their website for the CB500 so unless the 400/750 system fits it may be ruled out. Someone will know?
Cant think of another system other than Boyer that does away with the mechanical advancer.
« Last Edit: May 26, 2016, 06:57:33 AM by royhall »
