Author Topic: Electronic ignition  (Read 5505 times)
Offline Ashdowner
Re: Electronic ignition
« Reply #30 on: July 26, 2016, 08:21:07 AM »
I've had 2 CB550K3's - 25 years apart. the first one had Boyer ignition and it went like a dream with absolutely no problems. The one I have now has a DSS unit in it and it also goes like a dream - BUT......since I installed it my battery discharges if I have my headlight on. I know the Boyer system draws 1.5 amps (e-mail this morning) and I'm waiting for DSS reply to tell me how much theirs draws. If it's the same then it's obviously a charging/battery problem. The bottom line though is that in terms of performance I believe the units to be equal.
CB550K3, CB550K1, Yamaha Midnight Star, and CA77 in 2473 pieces (at the last count)
Offline masonmart
« Reply #31 on: July 30, 2016, 09:57:31 PM »
I bought a Boyer unit in the end. It is all electronic
Dresda CB500-4, 605 cc
CB-77, 350 cc
1968 Bonneville
1976 Thruxton Velocette
1974 Kawasaki Avenger
1997 VFR 750
Online Johnwebley
« Reply #32 on: July 30, 2016, 11:55:09 PM »
  I run Boyer ignition,and  H4 halogen  headlight,
 normal open road riding its works great,but if your stuck in town traffic for long,it can cause an issue,
Offline Ashdowner
« Reply #33 on: August 06, 2016, 10:01:41 PM »
I have the same problem. I've made a difference though simply by putting an LED stop/tail in. I'm also going to get LED's into the indicators (ok not a great win per £ spent) but if I'm in traffic mine suffers as well and the indicators don't help. Also going to get an LED headlight bulb which would make the biggest difference but I'm struggling to understand which one is best.
Offline ST1100
« Reply #34 on: August 07, 2016, 01:55:45 PM »
You'd need to check if the Evitek G6 H4 (with shield!) would be avail for LHS traffic...
Dunno if the heat-sink/fan assy will fit the headlight bowl though...
STOC #637
