Author Topic: SOHC IGN COIL REPAIR -- DIY CHEAPO REPLACE HT LEADS Also N.D. HONDA TWINS COILS  (Read 5746 times)
Offline JustcallmeMrT
Re: SOHC COIL REPAIR -- DIY CHEAPO REPLACE HT LEADS
« Reply #15 on: June 21, 2016, 08:24:18 AM »
MrT (Roger)   ...  In the write-up I used 7mm dia HT cable PVC HT cable  with multistrand core. Problem is I bought it off eBay a couple of years ago and trying to track down the seller. There are loads of sellers but I would like to include the source I used.
I got the same type off of eBay, along with the appropriate ngk resistor caps.  I didn't realise about the need for dielectric resin - glad you warned me!
Sent from my SM-N9005 using Tapatalk
« Reply #16 on: June 21, 2016, 09:32:41 AM »
I have copied the repair procedure in my Dropbox links
« Last Edit: June 21, 2016, 09:35:33 AM by AshimotoK0 »
« Reply #17 on: June 21, 2016, 11:10:17 AM »
Interesting that the Nippon Denso  'twins' coils are mounted to the aluminium frame with slotted type screws not 'JIS 'crossheads' .This was done as standard. Never seen slotted screws used on a Honda before !
Anyone know how much current the stock pair of coils typically draws?
2.5-> 3 Amps depending on coil temperature
Offline Seabeowner
Thanks for posting this. Most of us with only one or two (or three) bikes only come to this problem rarely and can make mistakes at the first attempt. The pictures give me the confidence to get on with mine.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Here are a few pics of my coil rebuild.  It's not pretty, I've still got to file back the putty but it all worked well - very pleased!
The one word of advice I'd give would be to use blu-tac instead of tape to make the barriers for the resin.  The tape allowed quite a bit to ooze out before it set and made quite a mess, however the blu-tac contained it perfectly.  It's a bit of a pain to get it all off of the resin before adding the putty but overall the results were well worth the efforts.
Thanks Ash!!
that looks good,when I replaced my coils I chickened out ,
and got a replacement set,
 they look very usable,and as they are hidden under the tank,the finish is not quite so important.
Great stuff Roger . One trick on the epoxy putty is to mould it to about the correct shape and let it cure for half an hour then moisten a rubber-gloved finger and smooth over the surface. Power file /wet'n'dry then  satin paint will sort out aesthetics on yours ( if you are bothered  ;)) .
 Problem with 'replacement' coils  is that if they are used and even off a low mileage bike, the PVC  outer of the HT coil will almost certainly be really hard and brittle after 40 years.
Give me a couple of weeks and I can duplicate my tester so you can spark test at full rate, off the bike and give it a 'soak' test ( then pass on to anyone else who wants to use it). All you will need is a battery or 3A power supply, no test gear like I used.
« Last Edit: June 27, 2016, 08:24:06 AM by AshimotoK0 »
Sounds like a plan!
Yes Ash, that is our Piki.........Diego Corral Jimenez. An absolutely delightful man to do business with.
« Last Edit: September 02, 2016, 11:35:11 AM by Nurse Julie »
Offline Piki
Just noticed someone is Spain is doing the numbers for the coil leads. Is this Piki on here?
http://www.ebay.co.uk/itm/HONDA-CB750-550-500-400-350-FOUR-COIL-NUMBERS-DECALS-HONDA-FOUR-/201659014611?hash=item2ef3d05dd3:g:kcIAAOSwtnpXnchC
Hello there, yes I am!!! If you need one of that, let me know!! Free for you!!
Offline Piki
Hello Julie, you are very great woman, other kit free for you if you are interested on it!!
Let me know!!
Best Regards.
Hi Piki.
Yes please, I also need some other bits as well, not free of charge, so I will PM you
xx
