Author Topic: Oil pressure dropped  (Read 2071 times)
Offline yozzer74
« on: June 28, 2016, 09:06:14 PM »
Had bike running today just in garage oil pressure was 60 then on tick over 20 but after 5 mins dropped down to 0 .but when reved goes back into 20 .is it because it got too hot .
Re: Oil pressure dropped
« Reply #1 on: June 28, 2016, 09:09:55 PM »
Low oil pressure at idle is not uncommon on warm/hot high mileage engines, if pressure returns above idle nothing much to worry about according to Honda manual. If however the engine has recently been rebuilt I would certainly investigate further!
Offline yozzer74
« Reply #2 on: June 28, 2016, 09:31:57 PM »
It has had top end rebuild new piston rings .valve guides .
« Reply #3 on: June 28, 2016, 09:42:06 PM »
Did you replace crank/conrod shells? What sort of shape were they in? It's those parts being worn that give rise to very low oil pressure, pistons/rings etc have no effect on oil pressure
« Reply #4 on: June 28, 2016, 09:44:00 PM »
Leave it to get cold again and try it to see if it gets back to 60 when first started with it cold to give you more of a read of the situation.
The top end should not have so much influence on absolute oil pressure as it uses restrictor jets in the supply to the head to help maintain pressure for the bottom end.......... You have installed the restrictors to the head during rebuild I guess?
Offline yozzer74
« Reply #5 on: June 28, 2016, 09:45:39 PM »
Yeah fitted those .
Offline UK Pete
« Reply #6 on: June 28, 2016, 09:50:41 PM »
I take it you have a pressure gauge, do you also have the red oil light,or can you connect it up, dont rule out a dodgy cheap gauge
Offline yozzer74
« Reply #7 on: June 28, 2016, 10:12:46 PM »
I haven't wired light up but I think I'm going to do it
Offline yozzer74
« Reply #8 on: July 13, 2016, 03:23:59 PM »
I've wired a oil light up and it goes straight out when started .but on the gauge it hasn't dropped below 20 .either but I haven't let it run for as long as I did before .
« Reply #9 on: July 13, 2016, 04:07:06 PM »
What oil are you using
Offline yozzer74
« Reply #10 on: July 13, 2016, 04:13:37 PM »
Think it was 10 / 40 semi.
« Reply #11 on: July 14, 2016, 05:47:04 AM »
Forget the semi it isn't worth the cost, and if it is hot used 20W50
Offline r1_pete
« Reply #12 on: July 15, 2016, 01:35:36 PM »
Its probably the oil pressure relief valve which is not seated properly, if the engine is left standing dry crap builds up as the oil coating deteriorates, when you run it again the valve lifts off it seat as it should to prevent over pressurizing, the valve then doesn't seat properly and allows oil to bypass all the time, instead of shutting off at low revs.
2009 Yamaha XJR1300 sold
1977 CB750F2 café racer project. Sold
1972 CB750K2 hot rod. Sold
and an E-Type Jaguar that considers itself worthy of all my spare cash. Sold
1971 CB450
1978 Reliant Scimitar Cosworth.
Offline westfieldandy
    • good-bits
« Reply #13 on: July 28, 2016, 04:07:54 PM »
Hi,
Just spent a fortune on tooling and stuff redesigning oil pump for the cb750, I've been testing the prototype now for 10 months and all seems good, wish i'd had one when we were racing.
anyway,  what you are describing does not sound uncommon to me,  most used pumps / engines with a semi synthetic 10/40 motorcycle oil, when the engine gets really hot, ( ie you cant hold your hand on the fins, ) its probable you will see 50lbs pressure when revving above 2500, below this it can drop to almost nothing at a slow tickover.  the oil light is designed to trigger at 8psi.
I have found 10/60 oils designed for air cooled harleys work very well in improving on this, but I now use much cheaper 10/40 semi. and it works well, but i do change regularily.
Its the sitting about in traffic or riding too slow that is the worse as the engine loves air flowing over it.
shimming the relief valve spring we always did to our engines, but, this only changes the upper cut off point to the maximumum pressure at high revs, ie it max pressure.
in old customers bikes displaying this problem, I have now sourced a reasonably priced 15/50 semi oil which helps this problem, or just change your oil more, and semi is less likely to break down with the heat, we had a lot of problems with oil when racing, if the bike got far too hot just once on the line or an extreemely hot meeting it never recovered viscosity again.
finally the full cure would be split the engine get the bearing clearances all good, get a good pump with good tolerances, check cam etc etc.
then you will find you will have 15/20 psi at hot tickover and 60psi above 2500 (relief valve wont let it higher).
ps, make sure you oil supply line is clear/ and not partially blocked or kinked.
www.good-bits.co.uk
https://youtu.be/cOcQZ2oVeFE
andy
« Reply #14 on: July 28, 2016, 05:50:26 PM »
Changing the relief valve spring and a good clean makes a shed load of difference. I sell the new spring to OEM standard and the stopper kit.
