Author Topic: Decreased Fuel Range :-(  (Read 1685 times)
Offline Honda Al
« on: July 08, 2016, 08:22:41 AM »
Hi all,
Since fitting my repro HM323 exhausts, the fuel range has decreased. I used to get ~95 miles before switching to reserve and now only get ~75miles.
Any ideas? Alan
I love a Honda. Proud father of a 2000 Honda CBR929 Fireblade and 1972 Honda CB500 K1. Oh, and two children!
Offline florence
Re: Decreased Fuel Range :-(
« Reply #1 on: July 08, 2016, 08:57:27 AM »
what did you have fitted before?  Maybe it's breathing properly now?
« Reply #2 on: July 08, 2016, 09:16:48 AM »
Check your jet sizes, often aftermarket pipes need larger jets to run properly, if you do have bigger than standard jets, that's where your fuel is going!
Offline Honda Al
« Reply #3 on: July 08, 2016, 10:22:02 AM »
It was a 4-2 system.
« Reply #4 on: July 08, 2016, 10:31:09 AM »
Jetting may well have been altered before you bought it, especially if it's a u.s. import, the yanks love fiddling with things for no good reason! Also, it could be down to your riding style, revving high through low gears in town etc.
« Reply #5 on: July 08, 2016, 11:16:28 AM »
also,check your airfilter,when I changed mine it made a massive difference,and it didn't look that bad .
Offline florence
« Reply #6 on: July 08, 2016, 11:25:43 AM »
+1 with the main jet, it makes a huge difference.
Offline Honda Al
« Reply #7 on: July 08, 2016, 06:14:34 PM »
Thanks everyone.
What other symptoms would the bike show/have if the jets were too big?
« Reply #8 on: July 08, 2016, 06:28:34 PM »
sooty pipes,
  no need to use choke ,
 sluggish performance
 dark plugs
Offline Honda Al
« Reply #9 on: July 09, 2016, 06:55:24 AM »
sooty pipes,
 dark plugs
Hmmm, I have all four. I'm going to investigate this weekend.
« Reply #10 on: July 09, 2016, 12:00:22 PM »
if you find your jets are wrong,it may be cheaper to get a set of rebuild kits from Cruzimage,
 last year,a set of 4 kits was less than £40 ,p&p included direct from japan,
they are on Ebay
« Reply #11 on: July 10, 2016, 06:08:44 AM »
Or go to Sirius in Canada and get a multi size jet "Kit"
Offline Honda Al
« Reply #12 on: July 10, 2016, 07:42:00 AM »
Had a quick look yesterday and it looks like I have 100 mains with 40pilots.
« Reply #13 on: July 10, 2016, 11:53:53 AM »
 those are standard for (my CB500) a K2 ,not sure about US imports,
next check the ignition timing,is it getting to full advance ? try a ride without the airfilter,,see what happens
