Author Topic: Oil pressure issue / motor rebuild  (Read 21895 times)
« on: July 13, 2016, 04:26:21 PM »
The good news is Candy runs well, looks wonderful, getting compliments from everyone who sees her, and has won best Japanese Classic at 2 of the 3 bike shows she has been entered in. However, it looks like she's about to be pulled apart. She has been restored at some point while in South Africa, but I've no idea what engine work, if any, was done until I get inside.
Fault 1:
While Candy runs ever so sweetly, with very little mechanical clatter, when she gets proper hot, such as after a run 2 up with the camping gear on board, I am sorry to say there is a definite low 'knock' which I can feel as well as hear. Pulling the clutch in makes no difference, so I don't think its the clutch basket rattle that some have suggested. Also, the oil light comes on at low revs, to be expected I know, the manual says it is normal, however the hotter it gets the higher the revs needed to make it go out again.
Fault 2:
This has only happened twice to me, but she is 45 years old, so who knows how many times it has ever happened.
200 yards from my house, (the same piece of road both times) the oil light comes on solid, not flickering, whatever the revs, and a clatter - as fast as I can pull over it goes as quickly as it happened and doesn't reoccur.
I suspect that fault 1 (the knock) was caused by fault 2 (oil starvation), and was already there when I bought her - coming back from the MOT (my first ride) I had issues with the oil light coming on at idle and being reluctant to go out again as I revved.
I have replaced the oil pump 'O' rings, oil pressure light sender, and tried heavier (20/50) oil. An experienced race mechanic I spoke to at Classic Le Mans last weekend suggested I could try over filling, with thinner oil, he suspects the thick cold oil just isn't flowing fast enough to keep up until it gets warm, leaving the oil pump trying to pump fresh air,  he agrees it may have done for the main bearing shells over time. He also told me about classic Bugatti race mechanics having to warm rear axles with blowlamps, the lubricant they use solidifies to something like candle wax at normal temperatures!
I'm going to try pulling the oil supply line at the motor, to see what the flow is like when the engine is cold - maybe it's partly the viscosity, but perhaps there's a partial blockage or collapsed rubber inner in the oil feed line (every other bit of rubber on the bike was shot due to a combination of age and long term storage in a hot climate).
Even if I can stop it happening again, the bottom end won't fix itself, and I am reading up about using plastiguage to measure running clearances. I wanted to take the motor out anyway to polish the cam cover. D'oh!  ::)
« Last Edit: August 04, 2016, 11:22:09 AM by MrDavo »
Re: Another oil pressure issue
« Reply #1 on: July 13, 2016, 05:06:45 PM »
Have you tested the oil pressure ? And is oil spitting out the tappet caps, when removed ?
« Reply #2 on: July 13, 2016, 05:13:11 PM »
No I haven't tested the pressure yet, but the local garage that does the wife's car has said I can use his gauge, he has a range of fittings so I'm hoping he has the one to fit on the end of the gallery.
There is oil at the tappets (and a slight top end leak).
« Reply #3 on: July 13, 2016, 05:29:11 PM »
Something really strange there.
You're already effectively running 20 viscosity oil anyway when the oil temp is down as the base oil is that rating and only behaves like a 50 when heated via the performance of its viscosity additives when reaching 100 deg c as I understand it.
Honda's manual for that engine states that SAE 20 oil is ok from zero deg c so you should not runs into problems from it at current temps.
I also ran these 750's on 20/50 oil including winter use of below zero and even got a K6 stuck in the snow with never any problem with oil pressure.
The pump is a dry sump so should never be able to suck air, as long as the levels are ok.
You may be onto something in verifying the oil hoses are intact internally as that could cause starvation. Have you checked the pressure relief valve on the pump?
« Reply #4 on: July 14, 2016, 05:53:14 AM »
There was a batch of oil feed lines fitted from the factory that had an internal "Kink" and restricted flow, as far as I know they should all have been changed under warrantee along with the crank and shells.
If you "clonk" is a bad bearing you will need a different crank and shells as these cranks can not be re ground
« Reply #5 on: July 14, 2016, 02:48:13 PM »
Oil light on steady with associated knock from the engine, that's a knackered bottom end for me. Take it off the road now before you do irreparable damage to the crank. Sorry mate.
Sent from my Nexus 7 using Tapatalk
« Reply #6 on: July 14, 2016, 04:59:50 PM »
If its knocking its already irrepairable mates
« Reply #7 on: July 14, 2016, 06:26:38 PM »
I suspect you're right, the crank is probably toast, but I'm not looking for a new one until I see for myself. I'm not going to run it until then, my 1200 Harley Sportster did a crankpin, then the metalflake oil did for all 4 cams as they seized in their bearings and span them in the cases. It took a year to fix that mess, if I'd stopped as soon as I heard it going 'potato, clank, potato, clank' I could've avoided a lot of the secondary carnage, but I went through a 'denial' phase first, until it became too loud to ignore.
The odd thing is that she runs very smooth and quiet until it gets hot and the oil thins, you'd think shot mains would knock all the time.
I do need to get to the bottom of 'why' first - if, say, the oil feed line is collapsing internally under the braiding, it could repeat the process even after I fix it, I will be having a close look when I get it apart, I may even replace it anyway as a precaution. Those two little episodes where the oil light came on as it suddenly lost pressure, then got it back, both with cold oil, just up the road from my house, are very significant I think, as well as very unusual. I shall also be having a very close look at the oil I drain out. I have an impressive collection of glitter that I washed (using white spirit) out of the Harley oil tank.
Not great, but not the end of the world either, I've fixed much worse.
« Last Edit: July 14, 2016, 06:39:45 PM by MrDavo »
« Reply #8 on: July 14, 2016, 07:58:24 PM »
A knock is usually a big end caused by the change of direction of the Conrod. Mains are usually a low rumble noise. As Brian says you can't regrind these cranks but if the damage is tiny they can be micro polished. Good luck with it hope it goes well.
Sent from my Nexus 6 using Tapatalk
« Reply #9 on: July 14, 2016, 08:03:28 PM »
Can be reground to STD size after metal spraying. You can't get oversize shells.
« Reply #10 on: July 14, 2016, 08:06:13 PM »
Have you had a crank metal sprayed Trigger? How did it turn out, I have one that could use that technique.
« Reply #11 on: July 14, 2016, 08:17:28 PM »
Cranks and cam shafts for the past 26 years ;)
« Reply #12 on: July 14, 2016, 08:44:36 PM »
Who do you get to do them Trig?
« Reply #13 on: July 14, 2016, 08:48:30 PM »
Roy, S.E.P. in Kegworth reclaim cranks by submerged argon arc welding then regrinding back to the original sizes. Used them myself, very good work, and they can usually supply shells as well.
« Reply #14 on: July 14, 2016, 08:55:34 PM »
T&L Engineering in Bedford.
