Author Topic: CB750 Barn find project - First Timer  (Read 57196 times)
Re: CB750 Barn find project - First Timer
« Reply #345 on: June 08, 2018, 11:15:55 PM »
You could try acetone (carb or brake cleaner) to dissolve the varnish sample.
Or from a plumber's supply,  the thinners they use on polypipe to clean it or thin the adhesive to see if either will have an impact.
Offline Underdog1
« Reply #346 on: June 08, 2018, 11:27:53 PM »
i left a chunk of the varnish in brake cleaner for 24hrs and again, had no effect. I suppose if could take longer than that but it didn't even soften
« Reply #347 on: June 08, 2018, 11:38:59 PM »
The polypipe thinners is different altogether so may be worth checking.
Used to use it alot but can't remember right now what chemical solvent it is.  Definitely not acetone though so could give a result.
« Reply #348 on: June 09, 2018, 08:34:09 AM »
If you look on the US site they seem to like Muratic acid---whatever that is
« Reply #349 on: June 09, 2018, 08:46:05 AM »
Where’s Ash when we need him?
2022 Tiger Sport 660
Offline Seabeowner
« Reply #350 on: June 09, 2018, 09:00:08 AM »
It's a shame he's not active, certainly missing him. Hope he's fine.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Offline sye
« Reply #351 on: June 09, 2018, 10:49:35 AM »
It would seem that Muriatic Acid is hydrochloric acid over here and it's most common use is as a brick cleaner:
https://www.toolstation.com/shop/p29118?r=googleshopping&rr=marin&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&gclid=EAIaIQobChMIg6vyl6bG2wIVaLXtCh0FlwSnEAQYASABEgJjEPD_BwE
It can also be obtained rather cheaply from chemical suppliers:
http://darrantchemicals.co.uk/muriatic-acid
Offline 71 V12
« Reply #352 on: June 09, 2018, 11:00:11 AM »
I don’t know where you are in the U.K. but this company cleaned my tank recently. I would say it was worse than yours. Like brand new inside now. They charge about £40 and turn around in 48hours.
Voith Industial Services
Warwick House, Watling Street
Wilnecote
Tamworth Staffordshire B77 5BH
United Kingdom
Just off the M42 jnc 9.
Kevin
Offline Underdog1
« Reply #353 on: June 09, 2018, 03:02:20 PM »
Engine back in, but turns out we’ve got a bit of a houseful today so not got much further.
Seems the powder coater missed taping the thread for the grease nipple on the swing arm. Tried cleaning it out best as I can and screwing it in but I think the grease nipple has started to cross thread
What size thread is it? 6mmx1mm pitch? I’ve got a tap I can run down it but wanted to check first as I don’t want to wreck the thread in the swingarm if I can avoid it - is this a known weak spot?
« Last Edit: June 09, 2018, 03:12:09 PM by Underdog1 »
« Reply #354 on: June 09, 2018, 05:47:54 PM »
Not normaly weak, that has to be a later swing arm if it only has one nipple underneath
Offline Underdog1
« Reply #355 on: June 09, 2018, 06:22:13 PM »
Yeah it is, basically what’s the best way to get paint out the thread?
Offline Underdog1
« Reply #356 on: June 09, 2018, 09:50:10 PM »
Well.. I ended up getting the grease nipple threaded in, huzzah! Can get the rear end all bolted up...
Maybe not. After I installed the swingarm I was moving the swingarm down to get the shocks bolted up and I managed to snap the grease nipple off against the engine casing somehow..
Really annoying. Might be because i had the grease nipple pointing forward towards he front of the bike, must be a really tight clearance thought.
On another not in having an issue getting my front wheel bearing retainer in, it’s a pattern part and it seems the threads are ‘tighter’ than the oem one I’ve got (which is mangled) a anyone else noticed this?
Offline Underdog1
« Reply #357 on: June 10, 2018, 09:57:40 AM »
Rear wheel laced up
And this is as far as I can get the front bearing retainer in, even tried hitting it with the impact driver  ::)
Offline MCTID
« Reply #358 on: June 10, 2018, 11:32:40 AM »
Mine was just the same......it was an absolute pig to get it out.....you should have seen the 'Heath Robinson' affair I rigged up on my Workmate to remove the rear Bearing Retainer (I'd stripped the rim off it - so it was just the hub).
I bought new Bearing Retainers but they also proved tight to insert so I asked my local Machine Shop to 'ease' out the threads in the Hubs......which worked a treat......well worth £20 for both Hubs.
The way I looked at it was that I wouldn't like the next person who stripped a Bearing out to go through what I had to.
Offline Underdog1
« Reply #359 on: June 10, 2018, 11:54:56 AM »
Might go down this route, was it the hub the machines the threads in or the bearing retainer? Might hold tight on lacing the front wheel up. Seems a bit of a joke to have these things staked in, on what planet are these things backing out?
Once all the bearing retainers are in I was thinking of putting a glob of locktite down each stake hole rather than restaking - any issues with this?
On a more positive note I got the snapped grease nipple out the swingarm
The first time in history an easyout has worked
« Last Edit: June 10, 2018, 12:00:37 PM by Underdog1 »
