Author Topic: Anyone know a source of frame tubing?  (Read 784 times)
« on: September 19, 2016, 08:05:52 AM »
One of my CB250K0's needs the bottom tube replacing. I could weld up the holes but I would rather do a proper job and TIG weld a new tube into it, as we have the bending gear at work and it's not a complicated shape anyway. A member on HondaTwins.net  (& also on here) suggested Reynolds 531 tubing. Anyone know where to buy frame tubing? I will measure the OD/wall thickness.
Offline RGP750
Re: Anyone know a source of frame tubing?
« Reply #1 on: September 19, 2016, 08:57:59 AM »
You could ask moto liner Ash they are really helpful.
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
« Reply #2 on: September 19, 2016, 09:07:00 AM »
Reynolds 531 if I'm not mistaken has traditionally not been welded by tig / mig as the temperature is a problem, it's usually brazed as you can get hardening effects local to the weld site that reduces integrity and promotes stress failure.
Think modern weld compatible Reynolds would be 520 or 525.
