Author Topic: Engine rework / Machinist up north  (Read 3596 times)
Offline cantarauk
« on: September 21, 2016, 09:02:19 PM »
Hi,
Are there any community users who know a machinist in the North of England that can take on engine / valve reworks at a reasonable price ? There seem to be no shortage down South or in the US but I am yet to find someone up north.
Re: Engine rework / Machinist up north
« Reply #1 on: September 21, 2016, 09:08:13 PM »
Hi,
For what engine ? and what do you need doing ?
Offline cantarauk
« Reply #2 on: September 22, 2016, 10:10:19 AM »
1972 CB500.
Looking for someone who could check valves for wear and if required replace. Cleaned and refaced with any other work that may be required. Valve seats recut if required and then washed and reassembling of the top end.
Cylinder head refaced and cylinder bore checked if a bore is required.
Offline stevush
« Reply #3 on: September 22, 2016, 11:48:13 AM »
SEP in Kegworth is not too far away from you, they're easy to deal with and OK with bike stuff, I can recommend them
Steve
Offline cantarauk
« Reply #4 on: September 22, 2016, 12:24:20 PM »
Great. Thanks for that Steve.
I work all over the midlands so will take a drive past there and have a word with them.
I have also just found W.DRAKE LTD Bradford - http://www.wdrake.co.uk if anyone has had any dealings with these guys and can recommend or Not !
Offline yozzer74
« Reply #5 on: September 22, 2016, 01:21:39 PM »
Blands&sons in barnsley did mine for me .
Offline totty
« Reply #6 on: September 22, 2016, 01:56:35 PM »
Probably too far north for you but I've had work done by Cleasby Crankshafts in Durham 3 or 4 times.
Offline RGP750
« Reply #7 on: September 22, 2016, 04:30:24 PM »
Another one in Durham
Jim Norman ,just done my K0 head and barrels.
07403148098
Good bloke to deal with
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline cantarauk
« Reply #8 on: November 21, 2016, 09:59:09 PM »
Has anyone had any work done by T&L Engineering
« Reply #9 on: November 21, 2016, 10:07:31 PM »
Yep, I was having breakfast with Barry (the owner) this morning. Have used and known for over 26 Years.
Offline cantarauk
« Reply #10 on: February 10, 2017, 07:03:38 PM »
Thank you all for the suggestions which I have now saved in a contacts list. In the end I have managed to get the parts to SEP do do the machining for me since I have been working on a project close by and have been passing on a weekly basis. Its going to take a while since they are rather busy but I have other things to get on with so no res rush.
What I was going to ask on the back of this post was if anyone has had their engines bead blasted rather than vapour blasted and if so what was the result.
Offline Rumpelkrankshaft
« Reply #11 on: February 11, 2017, 10:12:47 PM »
I can second Stevush regarding SEP-they did engine work for me of high quality but took rather a long time!
Offline jon stead
« Reply #12 on: August 07, 2017, 07:05:43 PM »
07403148098
I spoke to this guy today and what a helpful, knowledgable chap he is. He told me he has just recently set up a website.
http://www.milwaukeemuscle.co.uk/index.html
« Reply #13 on: September 07, 2017, 10:57:19 AM »
When I was trying to get to the bottom of my main bearings failing in a CB750 engine that was immaculate inside, the consensus on here was that bead blasting engine parts can lead to unexpected bad things happening - it only takes one bead to get into the tiny oilways in the head that feed your camshaft, for example, and get lodged where you will never find it, to kill your top end.
« Last Edit: September 07, 2017, 10:59:01 AM by MrDavo »
Offline Moorey
« Reply #14 on: September 07, 2017, 11:04:24 AM »
Ive been using Bland for over 40 years.
http://www.gblandandsons.co.uk/
