Author Topic: Cb550f oil leak  (Read 2246 times)
Offline peteuk
  • Honda CB550f
Cb550f oil leak
« on: September 23, 2016, 02:48:52 PM »
I wonder if anyone has any ideas about an oil leak I have on my cb550f. It's not really noticeable in the garden just ticking over but on a ride out it gets boot and trouser leg splatteringly bad. I've tried the talcum powder thing to try and locate the source of the leak but I'm struggling. I've attached a pic to give you the general idea. There seems to be 2leaks, both at the left side of the engine (as you sit on the bike),  one at the bottom of the fibs but the second i don't get cos the oil is collecting on top of the 6th final (from the top). This final is just ABOVE the join of the cases. I can't tell for the life of me where it's coming from. Any ideas, thoughts would be greatly appreciated.
Offline peteuk
  • Honda CB550f
Re: Cb550f oil leak
« Reply #1 on: September 23, 2016, 02:50:17 PM »
PS.  That should be fins not fibs
Offline peteuk
  • Honda CB550f
Re: Cb550f oil leak
« Reply #2 on: September 23, 2016, 02:51:42 PM »
PS. Again. 6th fin not final..... Bloody predictive text
Offline RGP750
Re: Cb550f oil leak
« Reply #3 on: September 23, 2016, 03:06:38 PM »
Had A similar thing a lot of years ago now, take a look at the tacho seal
if that model has one (mine was on a 500)
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline philgresty
Re: Cb550f oil leak
« Reply #4 on: September 23, 2016, 03:35:51 PM »
I had a similar problem when my crankcase breather was blocked, creating too much crankcase pressure and pushing oil out of anywhere it could. clean all the oil off and replace the crankcase breather hose.
if its not this, most likely the oil passage o rings between the head by the head gasket, these are known to leak on 550s.
Re: Cb550f oil leak
« Reply #5 on: September 23, 2016, 05:02:06 PM »
Usual oil leaks in order
(1) "O" ring in head gasket but usually only a small amount giving a "Mist"
(2) Sealing washer under the end cap retaining bracket(frequently missed out) NOTE SEALING
(3) Rubber pontefract cakes between rocker cover and head ( The heathens the other side of the water call them Pucks as they never heard of pontefract)
(4) Tacho drive seal or damaged housing
Offline peteuk
  • Honda CB550f
Re: Cb550f oil leak
« Reply #6 on: September 23, 2016, 05:27:59 PM »
Ahh I noticed when I Googled about it people talking about pucks. Didn't know what they were on about. Now I know. Does replacing the pontefract cakes mean taking the engine out of the frame. I think I may have to anyway as there is another leak right at the bottom where the fins start... ie below the first fin from the bottom
Offline peteuk
  • Honda CB550f
Re: Cb550f oil leak
« Reply #7 on: September 23, 2016, 05:31:44 PM »
By the way,  are these pontefract cake seals the same thing as the oil passage o rings that  philgesrty mentioned in an earlier reply
Re: Cb550f oil leak
« Reply #8 on: September 23, 2016, 06:01:52 PM »
No, the oil passage o rings are at head gasket level and base gasket level. You can strip down to base gasket level in the frame BUT READ THE MANUAL CAREFULLY
Offline peterengland
Re: Cb550f oil leak
« Reply #9 on: September 23, 2016, 07:27:45 PM »
I had an identical leak and it was  the rubber head cover seal, new one from DS and good as new now.
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Offline matthewmosse
Re: Cb550f oil leak
« Reply #10 on: September 23, 2016, 07:35:42 PM »
Note that even a single, small leak will spread out and make a major mess and genrally make the bike look like it is springing leaks everywhere. My wifes 250 nighthawk looses just enough oil to drop the level to the bottom of the dipstick from top every 1500 miles from an exhaust stud I sheared off and drilled a bit too far drilling it out. The resultant oil slick over my boots and the engine makes it look like it must be leaking from every gaskett and using a refinerys worth of oil.
Easiest thing to check is the cam end caps are sealed in the 3 correct points - eg the bolt as holds their brakett on the head, noting the alloy sealing washer etc are as per manual, and before now I have had oil peeing out of the O ring for the rocker spindle, or rather where the o ring should have been. After that the other thigs all require the head to come off ( appart from the pontefract cake things which only need the rocker cover off. I cannot say I have ever had one leak though, even though I re use them with a smear of heamatite on their seat before instalation.)
Offline peteuk
  • Honda CB550f
Re: Cb550f oil leak
« Reply #11 on: September 24, 2016, 12:00:09 AM »
Peter England you say you had an identical leak and it was the rubber head cover seal. Is that one of the 6 pontefract cake shape seals that another member mentioned? If not could you tell me what I should be looking for. Thanks
Offline peteuk
  • Honda CB550f
Re: Cb550f oil leak
« Reply #12 on: September 24, 2016, 12:35:44 PM »
Philgresty mentioned a blocked breather pipe. Not expecting much I removed the breather hose from the bottom of the airbox and just left it open to air, still connected at the other end to the top of the head. Took bike for a run, about half an hour, and guess what......no leaks. I don't know why as I have put all new parts in the airbox ie filter. The "element" is not available anymore so I made in as someone suggested out of scotchbrite, the green scouring pad stuff. Incidentally, when I bought the bike, thus hose was unattached to the airbox so I'm wondering if the previous owner had the same issue.
Anyway, any thoughts would be most welcome but as for now at least I come home with dry trousers and boots
Re: Cb550f oil leak
« Reply #13 on: September 30, 2016, 01:57:56 PM »
it's the long continuous rubber 'O' ring seal under the head cover, weird shaped thing
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Offline philgresty
Re: Cb550f oil leak
« Reply #14 on: September 30, 2016, 04:35:48 PM »
glad my suggestion has seemed to do the trick for you, hopefully thats all it was, too much crankcase pressure.
