Author Topic: 400 four kickstart  (Read 2501 times)
Offline dieffe
    • My website
400 four kickstart
« on: October 02, 2016, 11:47:39 AM »
Hi all, does anyone know if the 400 four kickstart lever is specific to the 400 or will any other model one fit?
The one on it is beyond repair and they are not a common item.
Re: 400 four kickstart
« Reply #1 on: October 02, 2016, 02:06:48 PM »
 The CB350 four will fit.
« Reply #2 on: October 02, 2016, 04:29:28 PM »
This is off the 350F ..not quite the same but will fit. 400/4 ones are rare and cost mega money. Just check with them its not off a 350 twin and make offer at least 10% less
http://www.ebay.co.uk/itm/Honda-CB350F-CB350-4-Four-1972-Kickstart-Kick-Start-Lever-Pedal-/331983661562?hash=item4d4bc4a9fa:g:l0sAAOSwLF1X6p6s
Offline dieffe
    • My website
« Reply #3 on: October 02, 2016, 10:51:07 PM »
Thank you very much for that, I was starting to think £120 was the best I could get one for.
« Reply #4 on: October 02, 2016, 10:56:54 PM »
Don't forget though that it will fit the 400/4 but not exactly the same & check that they have listed the correct part ...they a b*ggers for getting it wrong but in all fairness always seem resolve to your advantage.
« Last Edit: October 03, 2016, 07:56:38 AM by AshimotoK0 »
« Reply #5 on: October 03, 2016, 10:48:35 AM »
I bought a complete cb350f kickstart from the USA after giving up trying to get one in the UK. The actual lever was 30mm shorter then a 400/4 lever (I compared the 350 lever with my original 77 400/4 lever ) as I was only after the knuckle the length of the lever wasn't an issue but beware if buying from the US, ask the seller to measure the length of the actual lever before you buy.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline Chris400F
« Reply #6 on: October 03, 2016, 11:56:05 AM »
I bought a kickstart from Germany, from a CB350F that was being broken for parts.
It wasn't exactly the same as the original on my 1977 CB400F but unless you looked closely they were difficult to tell apart.
I don't know if it was the original or not but they were the same length, just a slightly different profile to the arm if I remember rightly.
I had photos of the two but sadly have tidied them up from my PC.
So I'm not sure what the difference is between the two.
Offline philgresty
« Reply #7 on: October 03, 2016, 01:12:38 PM »
I have one i think, was bought for my cb550 (was advertised as a 550 one) but the spline was smaller than the shaft.
if this sounds correct, message me and ill flog it to you cheap as i have no use for it.
Offline Chris400F
« Reply #8 on: October 03, 2016, 02:17:27 PM »
Here's a pic of the kickstart from my 400 to show the length if you want to check a prospective purchase.
If you look at photos of a 350F and 400F the kickstart seems to come to about float bowl height on both.
Maybe a 350F owner can confirm the length of the kickstart on that model.
Offline dieffe
    • My website
« Reply #9 on: October 04, 2016, 01:55:51 PM »
Thank you for that, message sent.
Offline Chris400F
« Reply #10 on: February 14, 2017, 03:58:21 PM »
