Author Topic: Engine teardown and inspection  (Read 13999 times)
Offline cantarauk
Re: Engine teardown and inspection
« Reply #120 on: January 09, 2021, 01:29:06 PM »
With the new parts that arrived and over the Xmas period to escape the insanity of been cooped up I braved the cold in the  garage to get some more work done.
Mainshaft assembly
All parts cleaned and checked
Before the first gear goes on the shaft there should be a circlip against the bearing. Note - Circlips are Honda specific which are flat one side and rounded/curved the other and shaped as show below.
Forth gear then gets pushed against the bearing flat side first.
Next the thurst washer and circlip to hold the gear in place
2nd and third mainshaft gear
mainshaft top gear
thrust washer
roller bearing and then all painted with some assembly lube
Drop the mainshaft into the top case aligning the middle gear shifter fork to sit between second and third gear. Align pin with the roller bearing and give a spin.
« Last Edit: January 09, 2021, 08:31:19 PM by cantarauk »
Offline cantarauk
« Reply #121 on: January 09, 2021, 01:51:56 PM »
Countrshaft cleaned and checked ready for assembly
replacement countershaft
Tope gear and circlip
Thrust washer and second gear
Thurst washer and lock washer which now fit since another replacement gear received
Third gear thrust washer and circlip
Forth gear
Lower gear with bush inserted with the flange side sitting against the forth gear
Needle bearing to top it off
Drop the countershaft in aligning the outer gear shifter forks to be positioned on forth and top gears
Online SteveD CB500K0
« Reply #122 on: January 09, 2021, 02:53:36 PM »
The people who designed these (without computers) have my admiration.
2022 Tiger Sport 660
« Reply #123 on: January 09, 2021, 03:58:54 PM »
As people used to say "Runs like a Swiss watch"
« Reply #124 on: January 09, 2021, 05:45:36 PM »
I'm sure there is a bulletin on the US site about circlips but talking about 750
Offline cantarauk
« Reply #125 on: January 09, 2021, 08:26:12 PM »
Thanks Oddjob - Have amended to add this sound advice
Offline cantarauk
« Reply #126 on: January 09, 2021, 08:26:32 PM »
Parts cleaned and ready for assembly
Shaft through bottom half of case with spring and circlip
gear
Thrust washer and large spring
Kick starter ratchet and thrust washer then small spring
Ratchet guide plate on next and push on on to compress the spring. As you looking at the ratchet from above the arm of the ratchet guide need to point down and will lock into the case. A not tricky but will have to keep it there with one hand while doing the rest.
Finally add the washer and then attach the circlip to hold it all in.
« Reply #127 on: January 09, 2021, 09:21:48 PM »
Hopfully i have attached a Honda buttetin and it dont throw your work out the window mate
Offline cantarauk
« Reply #128 on: January 09, 2021, 09:27:12 PM »
Thanks Bryan.
I have some very closeup photos so will check all circlips but from memory think they I were all assembled as per the service bulletin
« Reply #129 on: January 10, 2021, 01:08:19 PM »
😁Just a translation issue. They probably swear at the English language and words that sound the same with different spellings or same word meaning different things.
It sure confuses the hell out of the USA! 🙃
Offline cantarauk
« Reply #130 on: January 10, 2021, 02:36:47 PM »
Speaking of translation and presentation could someone please explain this to me so I know what is needed. For the clutch components No 12 is a spacer shown below.
But then how do I know what spacer I require for a 500K1 bike ?
I get the remarks with the greater and lower than the engine serials but how does one know what thickness ?
« Reply #131 on: January 10, 2021, 03:28:20 PM »
You need to choose the correct thickness to give the correct clearance, as detailed in the Shop Manual.
« Last Edit: January 10, 2021, 03:32:14 PM by AshimotoK0 »
« Reply #132 on: January 10, 2021, 03:30:50 PM »
Thicknessess of plates are all the same and in the manual and the different part number is square friction pieces not angular. the shims are not easy to get and you work out total play with no shim and a dti take off the clearance and fit shims to the resulting size, unless you are fitting new parts using the old one works
Offline cantarauk
« Reply #133 on: January 10, 2021, 03:43:15 PM »
Thanks both.
