Author Topic: Battery for converted 72 CB500  (Read 1814 times)
Offline cantarauk
« on: November 01, 2016, 09:29:30 PM »
I am currently converting a 72 CB500 and am asking the experts here for advice on whether a Shorai LFX14A2-BS12 would be adequate for my build. The electrics are going to have a complete overall and I will be replacing all legacy with newer components such as a motor gadget M-unit, new R/R, and then LED headlight, LED brake and indicators. The ignition will be replaced with Dynatech coil and ignition system.
Does anyone have experience with smaller batteries in their builds and what should i look out for ?
Glenn
Offline cantarauk
Re: Battery for converted 72 CB500
« Reply #1 on: November 01, 2016, 09:43:15 PM »
I Should add that I intend to use kick to start but would like the option of push start
« Reply #2 on: November 02, 2016, 09:09:14 AM »
need the full battery specs to comment. AH etc
Offline cantarauk
« Reply #3 on: November 02, 2016, 09:47:40 AM »
Hi Bryan
Battery specs are as follows:
LFX14L2-BS12
Voltage (Pb Eq) - 12V
A/Hr (Pb Eq)- 14
CCA (A) - 210
Max charge rate (A) - 14
Offline philgresty
« Reply #4 on: November 02, 2016, 11:16:15 AM »
youll be fine with that, i ran an 8ah battery in my kick only cb550 running a motogadget m unit and points ignition for a year with no trouble. the dyna ignition is a little more thirsty than points but not much.
« Last Edit: November 02, 2016, 11:21:49 AM by philgresty »
Offline cantarauk
« Reply #5 on: November 02, 2016, 04:13:49 PM »
Hi Philgresty,
Thank you for that. Are you running the dyne ignition now and if so the 3 or the 5 Ohm version ?
Glenn
Offline philgresty
« Reply #6 on: November 03, 2016, 08:47:38 AM »
Hey, i dont, my brother has dyna and a motogadget setup on his, as far as i know, the 3ohm is needed for the dyna s igntion, and the 5ohm is for standard points ignition
