Try our new info resource - "Aladdin's Cave" (Main menu)Just added a separate link to Ash's Dropbox thread (shortcut)
The choke lever on no.1 carb has a very, very small ball held by a spring. The spring pushes the ball into an indent when the choke is off.
Quote from: Laverda120 on November 07, 2016, 06:33:49 PMThe choke lever on no.1 carb has a very, very small ball held by a spring. The spring pushes the ball into an indent when the choke is off.Are you sure? I have been looking at the Parts List diagram and the assembly on my bike and I can't see anything like this, and in operation there doesn't feel to be any sort of location of this sort.
I stand corrected, well sort of. Yes, definitely a click but cannot see spring or ball bearing. He that knows all has just shown me on another set of carbs that are off of a bike where the spring and ball bearing is located. No wonder I couldn't see them !!!
Quote from: Nurse Julie on November 08, 2016, 04:39:12 PMI stand corrected, well sort of. Yes, definitely a click but cannot see spring or ball bearing. He that knows all has just shown me on another set of carbs that are off of a bike where the spring and ball bearing is located. No wonder I couldn't see them !!!Which bit should I be looking at Julie?I still can't see a spring or a ball bearing, and I had looked at exploded diagrams and the CMSNL part before the earlier post.Can't see anything that looks the part in the picture of the Link Set (CMSNL part 91).
It's the bit you can't see Chris ....
