Author Topic: CB466f  (Read 21441 times)
Offline Erwin83
Re: CB350f (466 big bore) - she runs!
« Reply #105 on: March 08, 2020, 04:42:10 PM »
Thanks everyone. “Understated cafe style”, if I would have had a goal at the start of the project(s), this would have been a nice statement to put it. I like that, thanks for the compliment.
CB466f - KTM 1190 advR
« Reply #106 on: March 11, 2020, 07:33:11 PM »
Like it a lot! That seat really sets it off...very retro 8)
Offline Erwin83
« Reply #107 on: March 31, 2020, 08:54:55 AM »
My other project is also getting along nicely:
Offline Erwin83
« Reply #108 on: April 01, 2020, 07:59:23 AM »
Needs some 2K, but all color is on  8)
Offline Erwin83
« Reply #109 on: April 23, 2020, 08:56:09 PM »
 8)
Offline Erwin83
« Reply #110 on: May 12, 2020, 08:30:37 PM »
Update of the "yellow one". Seat done, headlight done. Basically just the engine left to do and button up.
Offline Erwin83
« Reply #111 on: August 03, 2020, 09:51:22 PM »
Finally some progress on the yellow 350f, after I broke two oil rings while trying to install the cylinders, I had to order new rings from cruzinimage and stuff like that sets you back a couple of weeks.
This time I was more careful and the engine is now coming together.
Those 400 headers look so sexy  ;D
« Last Edit: August 03, 2020, 09:53:11 PM by Erwin83 »
Offline Erwin83
Re: 2 x CB350f Black 466cc cafe-style & yellow 350 tracker-style
« Reply #112 on: August 06, 2020, 10:35:11 AM »
Not finished, but it's getting there:
« Reply #113 on: August 06, 2020, 01:16:53 PM »
Nice... 8)
Offline Erwin83
« Reply #114 on: September 14, 2020, 11:46:01 AM »
Updates!
The black CB466f is smoke free since I changed the headgasket. I'm still treating here carefully as I will be doing a head re-torque after 500km of gentle riding.
Synched the carbs, and she's running like a sewing machine. Albeit a noisy one, with those 4 open pipes.
The yellow one is also getting close to being road-worthy. I had 2 test rides now, leading to altering the carbs (needle 1 position lower, I had it at max rich).
I also found that I have no battery charging during riding, there is no power to the white wire out of the reg-rec, which I guess means that my generator is not magnetized and therefore not working at all. It's a cheap reg-rec combo, I figure it's a DOA.
I also ordered a new silencer, so visually the bike is going to be finished soon.
Offline Erwin83
« Reply #115 on: September 14, 2020, 01:33:31 PM »
Did a little test: I had another old fashioned regulator laying around. So I unplugged the black and white from the new R/R combo, but let the 5 pin connector installed (using the R/R combo purely as a rectifier) and connected the old regulator.
Presto! I have charging power now. So the R/R combo must have some problem inside with the rectifier.
Bummer.
Is there any harm in riding with a R/R combo with the regulator unplugged, and using an old fashioned regulator instead?
I have no idea of the inner workings of a combined R/R.
« Reply #116 on: September 14, 2020, 11:25:43 PM »
As long as the loose terminals are insulated just in case it decides to play silly it should be ok
Offline Erwin83
« Reply #117 on: September 16, 2020, 04:45:03 PM »
Got the new silencer installed  8)
A silencer that actually silences! Unbelievable for <40 GBP (https://www.classicbikeshop.co.uk/short-daytona-36mm-44mm.html)
That means that this project is visually finished. Only some technical stuff to fix or improve:
- Carb jetting (main 90 now, seems rich) and need a synch.
- oil leak from the left side of the engine. Looks to be the O-ring of the oil gallery plug.
- Drive chain
- Longer jiffy (anyone know a plug-and-play option that is 1-2 inch longer?
- replace the R/R unit
« Last Edit: September 16, 2020, 04:48:29 PM by Erwin83 »
Offline SumpMagnet
« Reply #118 on: September 17, 2020, 06:47:42 PM »
Nice.
It's not really my style of bike, but I can still appreciate what's been done. The modern front end sits well and doesn't look out of place, which they often can do.
The swoopy 400-4 pipes and a short mega suit the style too.
It's clean, simple, and looks like a flat tracker.
Job done, and done well
CB750F2 - in pieces
Offline Erwin83
« Reply #119 on: September 18, 2020, 07:11:49 AM »
Thanks!
 :D
