Author Topic: Dynatek leads and stock plug caps  (Read 815 times)
Offline gordo
« on: December 20, 2016, 03:45:26 PM »
Hi guys dumb question time. Fitting  5 ohm dynatek coils and dynatek leads which have plug caps pre formed, any need to cut pre formed caps off and fit ngk 5 ohm caps?
Cheers gordon
Re: Dynatek leads and stock plug caps
« Reply #1 on: December 20, 2016, 05:22:37 PM »
Up to you.  I've got Dyna 5ohm coils and use the NGK HT caps.
Offline JustcallmeMrT
« Reply #2 on: December 20, 2016, 06:02:11 PM »
I used the dynatek caps.
Sent from my SM-N9005 using Tapatalk
Offline gordo
« Reply #3 on: December 20, 2016, 06:07:16 PM »
Cheers guys just wanted to check as have a set of caps if need. Will run the dyna caps and see.
« Reply #4 on: December 20, 2016, 06:20:33 PM »
But you need resistors, either in the caps or in the plugs ("R"), so check if your Dynatek leads/caps have built in resistors.
