Author Topic: crank cases  (Read 1000 times)
Offline kew
crank cases
« on: December 26, 2016, 12:49:59 PM »
HELP
I have a lot of old spares and decided that over the holiday I would sort them out.
I have a couple of sets of cases and don't know if they are matched pairs, how can I tell? :-[ :-[ :-[
I took the shell off my racing snail thinking it would make him faster.
It just made him more sluggish.
Re: crank cases
« Reply #1 on: December 26, 2016, 01:02:51 PM »
What bike's it from?
Offline kew
Re: crank cases
« Reply #2 on: December 26, 2016, 01:45:13 PM »
CB750sohc
Re: crank cases
« Reply #3 on: December 26, 2016, 07:51:24 PM »
Should have a letter and two or three numbers stamped on the flat part on the rear.
Offline kew
Re: crank cases
« Reply #4 on: December 26, 2016, 11:09:04 PM »
Thanks for the reply trigger.
I've just been down to the garage and none of my cases have any numbers on the back end.
Honda are obviously out to confuse me.
Re: crank cases
« Reply #5 on: December 27, 2016, 07:46:05 PM »
Must be a late engine. What is the number ? And any pictures would be a advantage.
Offline kew
Re: crank cases
« Reply #6 on: December 31, 2016, 04:34:59 PM »
I have sorted the problem, I fitted the mains as per the stamping on the top case and fitted the crank.
I then bolted in one bottom case and then the other, one turned and one didn't, problem solved. ;D 8)
