Author Topic: Perfect Timing  (Read 2741 times)
Perfect Timing
« on: January 30, 2017, 12:21:04 PM »
Ive set my CB750 timing up static as per the owner's manual, no problem, and it starts and runs OK.
However looking at the Honda Service Bulletins etc its clear that the dealer was expected to use a strobe, with a dwell meter.
The gist is that you set the dwell instead of the points gap, as it is a more accurate measure of how long the points stay open, then set the timing to the marks (I hope I've understood this correctly).
I can get a Gunson Superstrobe on fleabay for about £50, any good? Worth the extra effort?
Re: Perfect Timing
« Reply #2 on: January 30, 2017, 01:49:58 PM »
Much cheaper, but can I measure dwell with it?
Offline Chris400F
Re: Perfect Timing
« Reply #3 on: January 30, 2017, 02:24:45 PM »
No, but don't think that you could measure dwell with the Gunson one either.
You could with this: http://www.ebay.co.uk/itm/Vintage-Gunsons-Sparktune-2-Dwell-voltage-test-meter-Classic-Car-Good-Condition-/152408947464?hash=item237c47fb08:g:03AAAOSwUKxYcjeE
Re: Perfect Timing
« Reply #4 on: January 30, 2017, 03:21:33 PM »
Strobe light is a strobe light, Dwell meter is a dwell meter.
Re: Perfect Timing
« Reply #5 on: January 30, 2017, 04:10:07 PM »
The original manuals say use feelers and static timing, strobe is used only to check that the advancer is working correctly
Re: Perfect Timing
« Reply #6 on: January 30, 2017, 05:11:18 PM »
When servicing it would be much quicker for them to check dwell and timing without touching any setup, so all ok and leave alone.
If the points are set mechanically, then the dwell would usually be within range. It's the time the points are closed to allow coil saturation to occur.
Probably more useful on cars that have multiple peaks on the point's cam lobes as if there is a difference you'd get differing points gap depending or which one it's checked on. Dwell in that example would effectively aggregate the error to get a median points setup.
Re: Perfect Timing
« Reply #7 on: January 30, 2017, 07:29:39 PM »
And before you start any of this, make sure the carbs are nicely balanced.
Re: Perfect Timing
« Reply #8 on: January 30, 2017, 07:44:33 PM »
I bought a AccuSpark S8000 and after connecting pos/neg to battery and HT clip to HT lead doesn't produce a strobe light - Anybody else used this model? I suspect its the clip on HT lead that is loose fitting. Its some time since I bought it on ebay and no receipt (or know who I bought it off
Re: Perfect Timing
« Reply #9 on: January 31, 2017, 07:37:39 AM »
Is the HT clip on the correct way round, there should be an arrow on it. It won't strobe if it's wrong.
Offline Piki
Re: Perfect Timing
« Reply #10 on: January 31, 2017, 08:11:17 AM »
I have a original HONDA Dwell Meter with strobe inclued, 100gbp + shipping cost  ;D ;D, contact me if you are interested.
Regards.
Re: Perfect Timing
« Reply #11 on: January 31, 2017, 08:14:06 AM »
Regards.
Good morning to the Spanish salesman  ;D ;D
Offline Piki
Re: Perfect Timing
« Reply #12 on: January 31, 2017, 08:17:11 AM »
Good Morning to my UK friends, I love that country  ;D ;D ;D ;D
Offline Piki
Re: Perfect Timing
« Reply #13 on: January 31, 2017, 09:39:30 AM »
I sent a mail to the seller and the offer has ended.......
Re: Perfect Timing
« Reply #14 on: January 31, 2017, 11:25:54 AM »
I'll check Roy but from memory its fixed to the strobe HT lead as it came in the box and I'm sure it can only be clipped on one way
