Author Topic: Oil Pump Priming +(again!)  (Read 1055 times)
« on: February 22, 2017, 06:46:05 PM »
I've just fitted engine/pump and although I'm no where near start up (need sump on to route CR exhaust system) I have taken the general forum advice and packed the pump with vaseline. Can the experts on pump priming confirm that you just pack all the rotors/gallery's - ie there's no special technique?
Re: Oil Pump Priming +(again!)
« Reply #1 on: February 22, 2017, 08:29:25 PM »
From the £ shop and just pack it in before putting the pump back together.
Offline Underdog1
« Reply #2 on: February 22, 2017, 08:41:38 PM »
Is this a better method than just submerging it in oil and turning it to get all the air bubbles out?
« Reply #3 on: February 22, 2017, 08:49:53 PM »
Oil will just run out the pump with gravity ;) Don't ask me how I know this  :) :)
Offline bytio
« Reply #4 on: February 26, 2017, 09:25:45 PM »
Submerge pump in oil turn it over an lift the oil stopper/leak valve (very thin screw driver) turn the pump and immediately you will see the air bubble gulp out, release the valve you will instantly feel the extra resistance, I have done this many times and learned it's the only way to get  the oil pressure up quickly
« Reply #5 on: February 26, 2017, 10:04:30 PM »
That is fine, as long as your not building engines and sitting them on shelves for six months +.
Offline martin_uk
« Reply #6 on: February 27, 2017, 06:02:02 PM »
I had a problem every time, despite priming and trying vaseline.
Only thing that worked was making up an adaptor using a tubeless car tyre valve in rubber pipe and pressurising oil tank via the breather.
With plugs removed was able to get oil pressure light out before starting
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline adriangsmith
« Reply #7 on: February 28, 2017, 09:42:07 AM »
See my solution here. last post tells how i finally got mine going!
http://www.sohc.co.uk/index.php/topic,11713.msg90871.html#msg90871
Triumph Thruxton 2004
Honda CB750F1 1976
