Author Topic: What's my oil filter bolt got inside it?  (Read 1155 times)
Offline Ashdowner
« on: March 02, 2017, 03:28:36 PM »
Can't really see it very well here but the second hole from the right of the oil filter bolt is blocked by a piece of cylindrical metal (brass?) which has a spring below it (to the open end of the bolt) and this is held in place by a pin (small hole 2nd picture) going through the bolt. My question is what the hell is it? Also the holes in the bolt have all got bits of metal scarf as if the hole doesn't seem to have been finished of properly. Anyone else got the same?.
CB550K3, CB550K1, Yamaha Midnight Star, and CA77 in 2473 pieces (at the last count)
Re: What's my oil filter bolt got inside it?
« Reply #1 on: March 02, 2017, 03:57:50 PM »
Oil filter pressure relief/bypass valve. If the oil filter becomes badly clogged, the pressure forces oil through the valve to provide unfiltered oil to the crank etc to avoid totally destroying the engine.
Offline Ashdowner
« Reply #2 on: March 03, 2017, 11:25:15 AM »
Thanks hairygit. My oil change discipline is pretty good so I hope it never comes to that.
« Reply #3 on: March 03, 2017, 07:03:26 PM »
The technical term for the internals is "Gubbins"
Offline steff750
  • THE POWER OF DREAMS
« Reply #4 on: March 03, 2017, 07:32:33 PM »
Quote
yes and the unfiltered oil tends to take bits of crap that has been sitting there with it through the bypass valve ,so you might  still have a engine that is toast?
« Reply #5 on: March 03, 2017, 07:43:42 PM »
Quote
Indeed that may happen and the shells get knackered, but easier to fix than a seizure with shells spinning in the cases!
« Reply #6 on: March 03, 2017, 11:19:53 PM »
I thought they couldn't do that because of the cut outs / flat bit / whatever the proper name is.
Offline martin_uk
« Reply #7 on: March 04, 2017, 09:44:24 AM »
The tabs are just to accurately locate.
The shells are a "nip fit" in case/con rod, but if sufficient force applied due to seizure between bearing surface and crank journal, will rotate.
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
« Reply #8 on: March 04, 2017, 12:26:00 PM »
And if they do spin, there's a chance they'll knacker the crankcases!
« Reply #9 on: March 04, 2017, 08:45:09 PM »
Thats not a chance its a certanty
Offline Ashdowner
« Reply #10 on: March 05, 2017, 07:44:38 AM »
Wish I hadn't asked. I can't sleep at might now for worrying. Think I'll change my oil once a day.
Offline Ashdowner
« Reply #11 on: March 05, 2017, 06:29:57 PM »
Well my pressure relief valve wouldn't have worked at all because the holes in the bolt had scarf attached to them which had locked the piston solid - and it wasn't crap that had got there, it was crap that I had to physically part from the bolt itself because it had been left there from the manufactiure.
