Author Topic: Clutch cable  (Read 476 times)
Offline onethumb
Clutch cable
« on: March 04, 2017, 08:07:03 AM »
Hi, while my bike is in bits again I am going to replace the clutch cable as it's a bit tight. This is due to using slightly higher and longer bars. Can anyone recommend a direct replacement that is a 50mm longer?
Thanks.
Re: Clutch cable
« Reply #1 on: March 04, 2017, 08:27:41 AM »
Think it was quite common to use a CB500T cable for higher bars on the 750 over the years, gave enough extra for a reasonable choice of bars.
Alternatively, you could use someone like Venhill to supply one to your measured spec if you want to get a very close fitting with no surplus.
Offline onethumb
Re: Clutch cable
« Reply #2 on: March 04, 2017, 08:55:14 AM »
I'll check that out. Thanks.
Venhill stuff is amazing quality, I had them make up new throttle cables to marry to one of their push pull throttles.
