Author Topic: CB750 Carb body - desparately seeking  (Read 1356 times)
« on: March 07, 2017, 07:04:10 PM »
Now that I have stripped the set of carbs I bought last year for the CR750 project, I've discovered that no 4 carb is damaged (looks like they have been dropped) - the float bowl joint lip - on the main body is chipped. The mouth of the airfilter opening is also bashed. Before I go and buy a set of carbs just to use one carb body, has anybody got a spare they can sell me? Its just the body I need,
Re: CB750 Carb body - desparately seeking
« Reply #1 on: March 07, 2017, 07:16:34 PM »
show a pic of the damage, lip is not a problem
« Reply #2 on: March 07, 2017, 07:31:46 PM »
I know it would seal on the rubber seal (lip is to locate seal) - but the lip is visible on and as the rest of the carbs will be visibly like new (all re-plated/polished), just wanted to replace while they are in a milion bits - just wanted it 100% Graham
Offline MeilakJ
  • Life is what you make it!!
« Reply #3 on: March 07, 2017, 07:34:49 PM »
« Reply #4 on: March 07, 2017, 07:47:17 PM »
Cheers John - will see if anybody from UK can help to avoid postage costs from the States - if not its an option
Offline RGP750
« Reply #5 on: March 07, 2017, 07:59:34 PM »
This any good Phil?
Rich
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
« Reply #6 on: March 07, 2017, 10:20:15 PM »
I think that is No 3 carb Rich - its No 4 I'm after (air screw on right and fuel feed/brass male pipe for rubber balance pipe on left) - see pics
Offline RGP750
« Reply #7 on: March 08, 2017, 07:29:46 AM »
This one ??
The slide is stuck and i'm short of play time to get it out.
it's yours if yous want it.
Rich
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
« Reply #8 on: March 08, 2017, 11:33:37 AM »
Thats the one Rich - I'll PM you - Thanks
« Reply #9 on: March 08, 2017, 12:45:50 PM »
All now sorted thanks to RGP750 - donation made at Rich's request
Thanks again
« Reply #10 on: March 08, 2017, 02:38:36 PM »
Good result well done Rich...
Offline RGP750
« Reply #11 on: March 08, 2017, 02:48:16 PM »
Least i can do.
Had loads of help from here.
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
« Reply #12 on: March 10, 2017, 04:14:46 PM »
I got the carb from Rich today (Thanks Mate) - some slight differences that I need to see if they make a difference.
First the brass insert that the needle slides into (see CSML link and picture) sticks up higher than my carb - how do I get this out so I can change them over? http://www.cmsnl.com/honda-cb750k6-four-france_model14385/needle-setjet_16012392004/#.WMKgAjuLTIU
I guess it taps out but I have tried and it seems solid (unless I'm tapping from the wrong way)
Second, when looking at the roof of the float chamber, there are 2 holes - on the repacement carb, one with a brass reducer (like a jet) and one without - see pics. My original has no brass reducer in just the 2 holes. My other carbs (1,2,3 carbs) have one reducer - so it may be somehow its fell out - or No 4 carb may not have a reducer on that model/carb run (I bought them of ebay so don't know what model there off - the CR Rep has been built from parts starting with a K2 frame I had)
Carb markings are different - mine are '064A ANH' and replacement is '657A LC1'
Once again, any help much appreciated.
PHIL
« Reply #13 on: March 10, 2017, 07:28:40 PM »
You take the rubber duck and grab it by the neck, turning it towards the left  ;D ;D ;D
« Reply #14 on: March 10, 2017, 08:09:51 PM »
I think that will confuse everybody except you and me Graham!  :)
Sorted this now (Thanks again to Graham) - the needle 'guide' drifts out from the top - I tried it from the bottom.
Second question doesn't matter now as I can now use the carb that Rich provided
