Author Topic: Gear pedal shaft oil seal leaking.  (Read 527 times)
Offline Ashdowner
« on: March 08, 2017, 08:01:51 AM »
Any tips and tricks in replacing this? I assume it's a case of prising the old out and pressing the new in.
CB550K3, CB550K1, Yamaha Midnight Star, and CA77 in 2473 pieces (at the last count)
Re: Gear pedal shaft oil seal leaking.
« Reply #1 on: March 08, 2017, 08:21:25 AM »
If you prise it out, you may damage the case. You put a long screw through the seal ( not too far in ) and pull it out.
Offline Ashdowner
« Reply #2 on: March 08, 2017, 01:40:35 PM »
Thanks Trigger. That sounds good.
