Author Topic: power for sat-nav  (Read 1577 times)
power for sat-nav
« on: March 08, 2017, 02:56:54 PM »
hi all,
 just need advise on which is the best place to connect a power lead for a sat-nav ?
 ideally it will be switched on/off via the ignition,the negative lead can just be earthed ,
 thanks in advance,
  bike is CB500 K2 ,as my profile pic
Offline Tomb
Re: power for sat-nav
« Reply #1 on: March 08, 2017, 03:19:34 PM »
If just for Satnav I always take a live from inside the headlight bucket, that way its a switched live, and run an inline fuse. You can easily find a switched live with a multimeter or bulb and wire.
However when travelling abroad touring/camping I found I wanted to use a cig lighter socket for phone charging, this I wanted to do whilst the bike was parked so now have a permanently live socket under a sidepanel where I can stash the phone hidden. I use a £60 car Garmin SatNav so the cig socket is ideal for both jobs. Just a consideration.
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
« Reply #2 on: March 08, 2017, 03:31:54 PM »
thanks Tomb,
 I have a permanent USB socket for the phone,but wanted a switchable supply for the handlebar mounted sat-nav,
Offline Chris400F
« Reply #3 on: March 08, 2017, 03:46:31 PM »
Black wire looks to be switched live, and from the wiring diagram only the front stop light switch appears to be plugged in to a double connector so maybe a spare connection there.
If you are planning a socket near the handlebars what sort are you intending to use? Presumably it needs to be weather proof.
« Reply #4 on: March 08, 2017, 04:14:19 PM »
John, I have to ask WHY? You're of a generation that can read maps!
Offline Tomb
« Reply #5 on: March 08, 2017, 04:40:30 PM »
Yep, the oil light is live and not used once on the move (hopefully), you could piggy back off that too.
« Last Edit: March 08, 2017, 04:45:26 PM by Tomb »
Tom
'62 CB77 Sprinter
'70 CD175
'80 Z50R
Offline Chris400F
« Reply #6 on: March 08, 2017, 05:07:04 PM »
I was looking at the wiring diagram in the CB 500 & 550 Shop Manual in Ash's Dropbox (P144 of manual is CB500 K2 diagram).
I have no idea how to export a single page of a pdf file though!
« Last Edit: March 08, 2017, 05:25:54 PM by Chris400F »
« Reply #7 on: March 08, 2017, 06:52:39 PM »
Thanks Chris,Tomb,and Hairy,
 I shall have a play around and see what is the easiest,
 Yes, I can read maps,but I find the pages blow over if I go to fast,and get soggy when wet !!!
 I am hoping to explore the far reaches of Suffolk ,and areas,I know its very flat,so can't use hills as landmarks,-)))
 I know most of the roads in the west ,but for less than £90,I thought it would be an added help.
check it out
http://www.ebay.co.uk/itm/301977598178?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Offline paulbaker1954
« Reply #8 on: March 09, 2017, 12:39:33 AM »
I was looking for a cheap mounting alternative for the four ( I have a full garmin wired in mount on my Yamaha but it gets expensive just for the occasional use I wanted on the Four)
Bought a Bluefire phone mount that has an integrated USB power feed built in from Amazon for £15.99 that mounts really easily on one of the idiot light mounting bolts. It took 10 mins to wire in to a feed at the back of the headlight (spare black +ve and ground on existing connectors)
It JUST with a squeeze holds my Garmin 390 securely and I have been really impressed with the quality for the price. It holds smartphones also really well.
Can't see the actual one I got from Amazon but the EBay link below looks to be the same one and it's cheaper even 👍
Only downside is there is no in line fuse but that is easily rectified
Look at this on eBay:
http://www.ebay.co.uk/itm/X-Grip-Universal-Motorcycle-Cell-Phone-Mount-Stand-Holder-5V-USB-Charger-Socket/131820803614?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D41415%26meid%3D18d61c2943f94adfab101234d040b335%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D172318590619
« Last Edit: March 09, 2017, 01:26:41 AM by paulbaker1954 »
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline Tomb
« Reply #9 on: March 09, 2017, 06:47:59 AM »
Tom
'62 CB77 Sprinter
'70 CD175
'80 Z50R
« Reply #10 on: March 09, 2017, 08:12:02 AM »
Tom
I tried one of these with a cheap sat nav on my old Triumph
RUBBISH
Couldn't see screen in sunlight so constantly having to take my eyes off road (recipe for accident)
Eventually plucked up the courage to shell out on a Garmin plus Headset, expensive at around 500 all in but never looked back.
« Reply #11 on: March 13, 2017, 07:49:54 PM »
went for the first serious run today,
 used the sat-nav , it choose mainly main roads,odd short cuts ,but worked reasonably well,
 I bought a special bletooth headset with small earbuds to wear under the helmet,these worked brilliantly,easy to hear  over wind and road noise ,
 uses "noise cancelling " to make them better
well reccommended
https://www.amazon.co.uk/gp/product/B01LWI3M3F/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Offline Green1
« Reply #12 on: March 13, 2017, 07:59:01 PM »
When I collected the 550 I stuck the car satnav on the rev counter on the Guzzi.
It didn't like it on bit every corner or bump in the road it would turn the screen upside down so I would have to follow it backwards.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline bomber
« Reply #13 on: March 14, 2017, 12:04:10 AM »
Apologies for hijack,
I wonder how much does a phone charger and satnav drew, I was under impression that there is very little spear juice on CB550.
One step forward, two steps backward...
Honda CB550F 1976
Offline Green1
« Reply #14 on: March 14, 2017, 12:10:37 AM »
I shouldn't think they draw much more than 1amp
Even the 550 can cope with that
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
