Author Topic: Main Bearing clearance assistance  (Read 888 times)
Offline captaink
  • Old racers never die. ' they just go faster '
« on: March 15, 2017, 03:51:51 PM »
Hi All, I have just made a first main bearing clearance check on my 1977 CB750 engine using plastigauge.
The journals looked in really good order and originally they had Green shells on all 5 journals.
Although the shells looked good and unscored I decided to replace them anyway.
I have fitted new Green shells and the measurements are as follows:
Looking at the engine from the front:
journal 1  is 0.076
Journal 2 is 0.076
Journal 3 is 0.063
Journal 4 is 0.076
Journal 5 Generator end 0.050
I will take the readings again but how does this look
Any assistance appreciated
Regards Keith
CR750 Replica
Norton Manx's 1947 & 1956
Norton CS1 1930
Norton International  1934
Norton 16H 1924
Norton Model 18 1929
Norton Commando / Colorado Norton Works
Triumph 1947 GP Replica
Triumph Bonniville 1967
BSA Goldstar Daytona 1956
Harley Duo Glide 1961
The Rickman project
And the CR dick Mann replica project
Sold a few of the Bikes so only got these left
Gt40...Car I know
E type fhc 1964... Car I know
" Greedy I Know
Offline captaink
Re: Main Bearing clearance assistance
« Reply #1 on: March 15, 2017, 04:34:50 PM »
Hi All,
A 2nd reading taken and a more accurate torque wrench used, again looking from the front of the engine.
They look more equal but is this correct ?
Journal 1  is 0.063
Journal 2 is 0.063
Journal 3 is 0.076
Journal 4 is 0.076
Journal 5 generator end is 0.063 ..maybe a fraction over 0.063
Regards Keith
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
« Reply #2 on: March 15, 2017, 04:50:47 PM »
Havent got manual to hand but clearances are quoted in there
Offline archmill
« Reply #3 on: March 17, 2017, 06:45:39 PM »
Far as I know, industry standard is 1thou clearance all round ( 0.025mm ). Using your plastigauge, it pushes the crank away so there is no clearance at one side and double the clearance at the plastigauge. Therefore a standard 1 thou all round clearance should read 2 thou ( 0.05 mm ) with the plastigauge measuring card.
How do I post articles I did for a magazine ( word documents 4.8mb showing how plastigauge works and 4.2mb showing how to select cb750 shells ) ?
« Reply #4 on: March 17, 2017, 06:54:59 PM »
Try emailing to Ash (AshimotoK0)and he may be able to put in Aladdin's Cave sometime
Offline archmill
« Reply #5 on: March 17, 2017, 07:04:09 PM »
Just found this in the aladin's cave section :- http://info.sohc.co.uk/download/cb750/cb750_service_bulletins/750_14.pdf
