Author Topic: 1976 CB750f Rear Master Seals  (Read 2126 times)
Offline Moorey
« on: March 20, 2017, 06:14:48 PM »
 As its getting harder to find rear master seal kits for the 750f1 the 2 piston seals are the same as the ones in the front master cylinder. Both cylinders measure 14mm and both pistons 13.8mm.
Offline Moorey
Re: 1976 CB750f Rear Master Seals
« Reply #1 on: March 22, 2017, 07:28:10 PM »
Early GL1000 rear master cylinder seal kit 43510-371-305 will replace master cylinder seal kit 43510-392-305 for 1976 CB750f all it requires is 6mm cutting off the threaded pushrod.
« Reply #2 on: March 23, 2017, 07:41:01 PM »
I think I might invest in one as insurance for the future.
Offline Moorey
« Reply #3 on: March 26, 2017, 12:01:34 AM »
I am not quite as bothered now I know the front master seals are the same and easily available.
