Author Topic: 1978 Carbs  (Read 1309 times)
Offline Stoko
1978 Carbs
« on: March 21, 2017, 06:59:59 PM »
Hello, I have broken the overflow tube off the base of the No. one carb!! Is this repairable at all and if so how? Alternatively has anyone got a replacement they could sell me? Cheers.
Re: 1978 Carbs
« Reply #1 on: March 21, 2017, 07:03:20 PM »
Welcome to the forum. CMS have them new if all else fails   http://www.cmsnl.com/honda-cb750f2-super-sport-england_model14689/16015-kn4-a10-chmbset_16015393004/#.WNF4qsCLSM8    Bit pricey but at least you can get one.
Re: 1978 Carbs
« Reply #2 on: March 21, 2017, 07:17:40 PM »
Welcome Stoko - enjoy this great forum.
I am having the same problem as the set of carbs I bought for my CR750 project have a few snapped off. I am going to drill out and insert a brass tube. Have ordered some brass tube off ebay -
http://www.ebay.co.uk/itm/391714801139?_trksid=p2057872.m2749.l2649&var=660788072575&ssPageName=STRK%3AMEBIDX%3AIT
Will either use the above as a friction fit or drill and tap M5 and insert a 'drilled down the middle' m5 brass screw -
http://www.ebay.co.uk/itm/322377605112?_trksid=p2057872.m2749.l2649&var=511329139968&ssPageName=STRK%3AMEBIDX%3AIT
- which will provide grip for the rubber tube. You only need to drill in a small amount, hence not disturbing the internal tubing
Offline Stoko
Re: 1978 Carbs
« Reply #3 on: March 21, 2017, 07:31:30 PM »
Thanks for reply! Thought about pressing it out and replacing! Are these just a press fit! Dosn`t seem to be much room for tapping before disturbing the inner tube! Cheers.
Re: 1978 Carbs
« Reply #4 on: March 21, 2017, 07:45:22 PM »
I think we would struggle to press such a small tube out. You have approx 15mm of casting - my plan is to drill in about half that - not to drill all of tube out (which would mess up the overflow height) - hence just inserting the part that the rubber tube goes over. Its worth a go as the worst case is we'll have to get another float bowl. Good luck
Offline Green1
Re: 1978 Carbs
« Reply #5 on: March 21, 2017, 10:13:33 PM »
Hello and welcome
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Re: 1978 Carbs
« Reply #6 on: March 21, 2017, 10:24:27 PM »
Hello and welcome
Hi Mick, how are you today ;D
Offline Green1
Re: 1978 Carbs
« Reply #7 on: March 21, 2017, 10:28:39 PM »
I was waiting for that  ;D
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
Re: 1978 Carbs
« Reply #8 on: March 21, 2017, 10:41:00 PM »
You should say : Donation box is at the top of the page ;)
Offline Green1
Re: 1978 Carbs
« Reply #9 on: March 21, 2017, 10:46:30 PM »
Duly noted I shall drop a hint or two from now on.
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
Re: 1978 Carbs
« Reply #10 on: March 21, 2017, 10:48:13 PM »
We haven't had a... Glad you joined to sell your bike for a while now  ;D
Offline Green1
Re: 1978 Carbs
« Reply #11 on: March 21, 2017, 10:54:00 PM »
I like those ones they tend to have pictures  ;D ;D
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
Re: 1978 Carbs
« Reply #12 on: March 21, 2017, 11:14:13 PM »
This thread has a picture at the start  ;D ;D
Offline Green1
Re: 1978 Carbs
« Reply #13 on: March 21, 2017, 11:17:41 PM »
It also has a Hello  ;)
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
Offline Stoko
Re: 1978 Carbs
« Reply #14 on: March 22, 2017, 12:22:54 AM »
Excuse me!! Why are you seeming to  take the piss out of this post please?? First time on here and have a real problem that some people have responded to very well with sound advice/ suggestions and then I read posts from others that seem to be taking the Mick!! Have I missed something here?
