Author Topic: Weak spark advice please  (Read 795 times)
Offline Johndoc
« on: March 23, 2017, 04:32:01 PM »
Ok so the bike was running fine last season, left it neglected over the winter. It will not start now. There is a weak spark at the plug, fuel seems fine, carbs all good with fresh fuel. It has new coils, leads NGK caps, points, condensers and plugs. I am stumped! Probably missing something obvious but just cant see it at the moment.  The coils are aftermarket, however it makes not difference when I try an original set. Any advice will be gratefully received.
Re: Weak spark advice please
« Reply #1 on: March 23, 2017, 04:37:21 PM »
New points? Did you clean the greasy gunk from the point faces that is put on as a corrosion inhibitor, if you didn't it will cause problems. Also check for loose connections, particularly the junction by the back brake switch where the points wires join the main loom, often get corroded inside and need cleaning after a lay up.
Offline Johndoc
« Reply #2 on: March 23, 2017, 05:09:06 PM »
Thanks Hairy, will check the wires, never thought of that. The points are new but bike did run with them, will clean them.
Offline Seabeowner
« Reply #3 on: March 23, 2017, 05:36:23 PM »
If it's like the 500 the 12V has a long way to go to get to the coils. Ignition switch, fuse, handlebar cut out switch and lots of connectors and long wiring. When the points are open you should get near battery voltage at coil. Common mod on classic bikes is to fit a relay so that the 12V goes strait to the coils. (with only a fuse in line)
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Offline Integra99
« Reply #4 on: March 23, 2017, 05:51:30 PM »
all of the above as said but having had similar issues with another bike... worth looking at Plug gaps? weak battery?
Offline Johndoc
« Reply #5 on: March 23, 2017, 08:49:39 PM »
This forum is amazing, and Hairy you are a genius! Opened up that connector behind the brake switch and sure enough there was verdigris on the spade of the green wire. Cleaned it up, pushed the button and away she goes.
Thanks again :)
