Author Topic: White field coil wire to stator  (Read 891 times)
Offline Niko
« on: April 02, 2017, 06:42:13 PM »
Hi,...I fitted a combined reg and rec.
The only way I can get it to work is to add a separate switched live to the whites.
I originally fed power to the reg using a black cable only....but no joy.
I assumed the unit would output 12 v to the white wire ?
Can anyone shed any light please.
Offline Niko
Re: White field coil wire to stator
« Reply #1 on: April 03, 2017, 02:38:31 PM »
Anyone....before I bugger about with it again
« Reply #2 on: April 03, 2017, 04:37:56 PM »
If you have put 12 volts into the white wire of the reg/rec you may have fried it.
Offline Niko
« Reply #3 on: April 03, 2017, 06:22:13 PM »
Hi...
It wasn't working before...nothing coming from the 3 yellows on the stator.
That was with a switched feed to the black and a red wire back to battery. White on the stator was to white on the reg rec.....but no voltage at the white
With the white powered up....I get a result from the stator.
I wanted to know if the rec reg should output voltage to the white.....and not need an extra feed.
« Reply #4 on: April 04, 2017, 06:58:53 AM »
The electronic reg/rec, when wired correctly, need no extras inputs. If it does not work it is either defective or wired wrongly which 90% of the time makes it defective. There should have been a wiring diagram with it as colours do not always match with aftermarket units
Offline Niko
« Reply #5 on: April 04, 2017, 09:18:07 PM »
Cheers....just waiting for a replacement.
Offline Brian G
« Reply #6 on: April 09, 2017, 01:12:07 PM »
I hope the replacement works out for you. I have/had the same issue with my newly rebuilt 400/F. The E-Bay reg/rec sold as specifically for the 400/F plugged right in but I could read only 0.05VDC on the white and no increase in voltage at the battery or on the white with variations in rpm. When I put a jumper between the black and white wires, all seemed fine. I'll be plugging in the replacement later today and I hope it works - otherwise I'll be thinking I did something wrong with the new wiring harness - odds are against me getting two duff units in a row, aren't they? :P
1975 Honda CB400F Project
1979 Honda CBX
1978 Honda CB550K
1976 Kawasaki KH400
1969 BSA Rocket 3
2008 Kawasaki C14 Concours
Offline Niko
« Reply #7 on: April 09, 2017, 07:30:21 PM »
I have voltage on my white now and a positive feed back to my battery.
Sent from my SM-G935F using Tapatalk
