Author Topic: Piston Rings  (Read 772 times)
Offline petermigreen
Piston Rings
« on: April 09, 2017, 01:29:24 PM »
Rather clumsily managed to break a ring during disassembly today. So obviously need to get a new set.
Question is this. Am I correct in thinking that if cylinders are on standard bore then the pistons will have NO numbers on the top surface?
Anybody got any sets?
Thanks, Peter.
Re: Piston Rings
« Reply #1 on: April 09, 2017, 01:38:41 PM »
Pistons are not always marked with the size but the rings always are by the gaps usually with a letter on one side of the gap and numbers on the other. If no numbers its standard then 25, 50, 75 or 1.00.
Numbers/letters always face upwards
Re: Piston Rings
« Reply #2 on: April 09, 2017, 01:40:53 PM »
Very helpful thanks, I'll clean them up and have a closer look, under a magnifying glass.
Re: Piston Rings
« Reply #3 on: April 09, 2017, 02:13:14 PM »
Just an 'R' on middle ring. No markings on top rings does that mean they are non directional?
Peter
Re: Piston Rings
« Reply #4 on: April 09, 2017, 05:40:13 PM »
Should be markings on the top ring, where did you get them from ?
Re: Piston Rings
« Reply #5 on: April 09, 2017, 05:55:53 PM »
they came in the engine. I was under the impression they are the original rings. Maybe not.
Peter
Re: Piston Rings
« Reply #6 on: April 09, 2017, 06:11:26 PM »
Sorry, I assumed that you had broken a new ring. Fitting old rings is a false economy in my book, you will have to cross hatch the bores to get new rings to bed in.
Re: Piston Rings
« Reply #7 on: April 10, 2017, 06:41:35 AM »
If they have been in a while there can be enough wear on the side to remove any light marking. R is a common one with nothing else means standard
Offline Seabeowner
Re: Piston Rings
« Reply #8 on: April 10, 2017, 09:21:14 AM »
Peter, I could not work on bikes without 6""digital calipers. They are pretty cheap, but maybe avoid the £5.99 variety. £20 would do it. Measure the max dia. of the piston skirt and even after a considerable mileage that should still be pretty close to the bore size.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
