Author Topic: CB550f1 petcock to carb fuel line routing  (Read 529 times)
Offline orangepeelneil
« on: April 12, 2017, 08:23:20 PM »
Hi everyone,
I'm replacing the perished fuel lines on my 550f1 and bought some cloth covered lines.
The routing from twin petcock outlet to carbs seems tight and I can't seem to get it good without crimping it.
I stilll need to cut to length.
Any ideas?, Does anyone have any photos a nice routing example?.
Cheers neil
Re: CB550f1 petcock to carb fuel line routing
« Reply #1 on: April 12, 2017, 09:43:59 PM »
Oh boy, I'm afraid you've routed them wrong. They have to go through a special hole in the carbrack frame more or less opposite the nipples of the T-joints. Means you have to go through the process of sliding them over those nipples again, that is after you have routed them through those holes. Length for tube to carb 3+4 should be 28 cm, for tube to carb 1+2 17 cm. Ideal ⌀ is 5,5 mm.
« Last Edit: April 12, 2017, 09:45:49 PM by deltarider »
