Author Topic: Carb rebuild kits  (Read 1398 times)
Offline Valentinik
Carb rebuild kits
« on: April 23, 2017, 06:08:49 PM »
I'm just about to start rebuilding a set of '72 500 carbs for my bike. I'm looking to replace all seals o rings, jets etc.
Is there a preferred brand/supplier of car brebuild kits I should buy?
Mike
Re: Carb rebuild kits
« Reply #1 on: April 23, 2017, 06:11:47 PM »
There is a man in Holand does a complete set of O rings, felt seals not available and top paper gaskets can be made
« Reply #2 on: April 23, 2017, 06:23:08 PM »
Mike
Search ebay for Cruzimage.they do a great set.sent from Japan quickly
4sets plus postage could be under £50.
Can recommend
« Reply #3 on: April 23, 2017, 06:37:20 PM »
+1 on Cruzinimage carb kits. I have never had a problem with them. (I'm sure someone will be along soon to tell you they are crap as opinions are well divided on carb kits)
Offline petermigreen
« Reply #4 on: April 23, 2017, 08:08:10 PM »
Agree in part with cruzinimage as I did my 400 with a set. However, when I recently did my 500 I could not source a set from them as they were either out of stock or have stopped doing them.
Instead I got a set from 4into1.com. Price was very reasonable and arrived in about a week. I just fired the 500 up yesterday with the new parts in and she goes very nicely. So can recommend the parts if you can't find the cruzinimage ones or any others.
http://4into1.com/carburetor-repair-kits-complete-set-honda-cb500-1971-1973/
Peter.
Offline Valentinik
« Reply #5 on: April 27, 2017, 08:01:55 PM »
Thanks for the input everyone, I did contact cruzinimage about buying a set from them but got no response. I will go for a set from 4into1 hopefully they will do the job.
Mike
Offline kevski
« Reply #6 on: April 28, 2017, 07:23:41 AM »
I used 4 into 1 for my 350, had to polish the float needles a bit, but would certainly use again.
« Reply #7 on: April 28, 2017, 08:04:56 AM »
I have used these a few times now and they have been excellent.
http://www.motorradbay.de/shipping-ct-47.html
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
Offline Colonial-Clive (yindi)
  • Colonial_clive
« Reply #8 on: April 28, 2017, 04:21:44 PM »
Gerban van der Meer in Holland did mine the best 200 I spent came back like new and bench set, put on bike let petrol in started 3rd hit of the starter.
Offline Ashdowner
« Reply #9 on: April 28, 2017, 07:34:04 PM »
Depends what you want to do with the carbs - replace everything or just do the O-rings and gaskets . Gerben is the guy who put me onto the O-rings that work on the petrol tubes between the carbs as nobody seems to be able to get the originals. They are 9mm OD and 5mm ID Vitron and mine are perfectly sealed. Available from all the O-ring stockists. The other O-rings I got out of a metric O-ring set I bought for £8 from a car parts place. The gaskets from the bowls you can either get in refurb kits as the correct shape or get the large O-rings which you have to bend and somehow keep in place when you put the bowls back on - not easy but can be done.
CB550K3, CB550K1, Yamaha Midnight Star, and CA77 in 2473 pieces (at the last count)
Offline Valentinik
« Reply #10 on: May 04, 2017, 01:51:04 PM »
Thanks for all of the replies guys. I've cleaned up the jets,etc  so I think I will go with the o-rings from Gerben.
Mike
