Author Topic: Throttle screw under grip?  (Read 754 times)
Offline paulbaker1954
« on: May 03, 2017, 11:54:43 PM »
Anyone know the purpose of the large spring loaded adjusting screw underneath the throttle grip?
I can't find any mention of it in any manual
I guess it's to alter the rate of return of the throttle when it's let go. Is there a specific way to set it?
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Re: Throttle screw under grip?
« Reply #1 on: May 04, 2017, 08:15:58 AM »
Its there to make the twist grip harder to twist, like a cheap cruise control. Was not fitted on later models
« Reply #2 on: May 04, 2017, 08:46:49 AM »
its perfect for warming up,set it around 2.000 rpm while you put the jacket and helmet on,
ideal,just loosen it after to ride away !!
Offline gtmdriver
« Reply #3 on: May 04, 2017, 10:34:21 AM »
Used to be a standard fitment on older British bikes too.
An adjustable friction lock for the throttle.
« Reply #4 on: May 04, 2017, 11:22:58 AM »
Got one on my BMW, never use it.  I prefer to be in control.
Offline matthewmosse
« Reply #5 on: May 04, 2017, 08:06:14 PM »
Got one on my k0 500/4, very crude cruise controll. I doubt I'd use if it the bike gets done up and running.
« Reply #6 on: May 04, 2017, 08:55:00 PM »
I have one but never used it. If it was ment as a cruise control (which I doubt), I consider it as outright dangerous.
« Reply #7 on: May 05, 2017, 02:00:42 AM »
Thanks all I am now fully enlightened 😀😀😀
Offline ka-ja
  • ken
  • yoshi 460
« Reply #8 on: May 05, 2017, 09:11:36 AM »
Hi all,
          Back in the old (pre-indicator) days, most bikes had a throttle damper of sorts to stop the bike standing on its nose when you stuck your right hand out to signaling to turn right!
nice bike,nothing in the bank
Offline florence
« Reply #9 on: May 05, 2017, 09:31:47 AM »
I don't have, or indeed like indicators.  The trick is to let the throttle off slowly and time things well.  The other skill is making sure you are in the correct gear for a left turn.  For people used to using hand signals only it becomes second nature.
In the last thirty years I've only ridden a bike with indicators for a few months.  I kept leaving them on by mistake which I think is pretty dangerous when approaching a left turn junction.
Offline ka-ja
  • ken
  • yoshi 460
« Reply #10 on: May 05, 2017, 03:28:14 PM »
No indicators on my cafe racer either, not "old school image", and I am definately old school,never mind the bike!
