Author Topic: Clutch cable  (Read 943 times)
Offline DJ7OOK
Clutch cable
« on: May 11, 2017, 10:18:26 PM »
Hi, I have recently purchased a 1977 CB550 F2. The previous owner replaced the clutch cable which I believe is too long. Do the clutch cable lengths vary from year to year or model to model?
Re: Clutch cable
« Reply #1 on: May 11, 2017, 10:40:05 PM »
with a lot of US imports,they have high bars,and need longercable
is yours a UK or US bike?
maybe see if someone could supply  lengths of each
Offline DJ7OOK
Re: Clutch cable
« Reply #2 on: May 12, 2017, 06:27:01 AM »
It's a uk bike and the handle bars are original.
Re: Clutch cable
« Reply #3 on: May 12, 2017, 07:34:18 AM »
Maybe PO ordered the wrong one. Consult p. 39 of your Parts List: http://www.honda4fun.com/pdf_parts_list/pdf_spac550/CB550F2/CB550F2_2.pdf
Re: Clutch cable
« Reply #4 on: May 12, 2017, 01:31:08 PM »
A lot of generic "pattern" parts list the same cable for all 500/550/750 fours so it probably does not fit any of them properly, proper Honda one isn't cheap but usualy better
Re: Clutch cable
« Reply #5 on: May 12, 2017, 03:34:00 PM »
Quote
Here is why. Look at the details and compare with imitations.
Re: Clutch cable
« Reply #6 on: May 12, 2017, 04:28:27 PM »
Big thing to remember with genuine cables is NEVER EVER LUBE THEM It swells the rubber/nylon linings and makes them bind
Re: Clutch cable
« Reply #7 on: May 12, 2017, 04:41:08 PM »
Quote
Recently my clutchlever is very hard to operate*. Some years ago I lubed the OEM cable with some WD-40. I thought it was harmless. Maybe it wasn't. On the other hand the cable is the first replacement and now has served some 70.000 kms. Next week I'll have a look behind the sprocket cover. Bryan, do you have a tip to free the cable down there from the thingie. Last time I was there I couldn't widen the slot where the bottom end of the cable sits.
*Could this indicate a snapped rod?
Re: Clutch cable
« Reply #8 on: May 12, 2017, 05:07:07 PM »
Only way I know of is large bits of jiggery pokery along with a modicum of BF&I
Re: Clutch cable
« Reply #9 on: May 12, 2017, 06:14:06 PM »
Quote
BF&I
? Please explain to a non native speaker.
Re: Clutch cable
« Reply #10 on: May 12, 2017, 07:31:32 PM »
Quote
BF&I
BRUTE FORCE & IGNORANCE, its all most hardly dangerous and shitalian bike owners understand!
Re: Clutch cable
« Reply #11 on: May 12, 2017, 10:12:33 PM »
Hairy you translate so well!!
its hard to describe but there is a small "tang" under the cable nipple that needs bending down so you can slide the nipple down till you can wangle the cable out the slot-----still prefer my first answer!!!!
