Author Topic: 1978 Carb clips  (Read 648 times)
Offline captaink
  • Old racers never die. ' they just go faster '
1978 Carb clips
« on: May 15, 2017, 04:02:04 PM »
Hi, Do you know if the jubilee style clips used on the CB750 engine to carb and carb to airbox are the same throughout the 1970's model range.
Silvers have clips for the early models but not listed on the 1978 model they have different part numbers and the 1978's are discontinued apparently.
If the rubbers are the same then the clips from the earlier ones must fit ??????
There a narrow band and hard to find elsewhere.
Cheers all
Keith
CR750 Replica
Norton Manx's 1947 & 1956
Norton CS1 1930
Norton International  1934
Norton 16H 1924
Norton Model 18 1929
Norton Commando / Colorado Norton Works
Triumph 1947 GP Replica
Triumph Bonniville 1967
BSA Goldstar Daytona 1956
Harley Duo Glide 1961
The Rickman project
And the CR dick Mann replica project
Sold a few of the Bikes so only got these left
Gt40...Car I know
E type fhc 1964... Car I know
" Greedy I Know
Re: 1978 Carb clips
« Reply #1 on: May 15, 2017, 04:14:58 PM »
The K7/8 and F2/3 rubbers are different to the rest of the range to suit the dreadful PD carbs, so I would imagine the clips may differ.
Re: 1978 Carb clips
« Reply #2 on: May 15, 2017, 05:30:28 PM »
Very difficult to get the correct F2 clips, if at all. After a fruitless search I ended up getting my old ones re-plated and fitting new screws. From experience, avoid the Jubilee type if you can as when they are tightened they have a lump where the worm screw is and it causes air leaks. If you want to try them though they are available in 9mm plated or stainless.
