Author Topic: Push or pull throttle cable  (Read 1235 times)
Offline chrisf1
« on: May 18, 2017, 01:52:01 PM »
Hi again everyone like I said the problems are starting the throttle appears to be the push and pull type but it only has one cable which has a very small bit of movement all the way to the carbs the cable is connected to the front of the throttle and I would imagine it is the pull cable ? would only having the one cable cause the throttle to appear locked? the cable that is connected goes to the back of the carbs and the other connects further forward so which one should I order is mine push or pull thanks Chris
Re: Push or pull throttle cable
« Reply #1 on: May 18, 2017, 03:39:48 PM »
At the handlebar end, is it in the front or rear hole of the twistgrip?
Offline chrisf1
« Reply #2 on: May 18, 2017, 04:18:11 PM »
The rear hole on the throttle has no cable thanks Chris
« Reply #3 on: May 18, 2017, 04:33:39 PM »
Right, what you have is on the parts list as cable A, which SHOULD be connected to the upper quadrant at the carbs, often referred to as the PULL cable, so you need cable B, often referred to as the PUSH cable. Make sure when ordering that you state U.K. model or U.S. as the u.s. model has longer cables due to the higher bars! ;D
« Reply #4 on: May 18, 2017, 04:38:54 PM »
Ah, just had a look at your bike pic, those handlebars are obscene :o! Due to the bars, you may well need a custom made cable, Green 1 (Mick) can probably give you the details of where he had some made recently, they were reasonably priced, so I would buy BOTH cables from them, because sod's law says a few days after fitting the push cable, the pull cable will break, then you're off the road while another is made!
Offline chrisf1
« Reply #5 on: May 18, 2017, 05:51:48 PM »
Hairy git thanks for your reply about the gables I will order both and extra long but I have done a members search for your friend with and without (mick) and not found how would I contact him thanks Chris
« Reply #6 on: May 18, 2017, 06:15:59 PM »
His name on here is  Green 1  his name is Mick!
Offline chrisf1
« Reply #7 on: May 18, 2017, 08:02:28 PM »
Found him and believe I have messaged him it disappeared when I clicked spellcheck thanks Chris
Offline Green1
« Reply #8 on: May 27, 2017, 09:30:14 PM »
Just seen this never received your PM. The left over cables I had went on eBay and sold instantly  I should have had more made  ::)
I used Venhill cables  http://www.venhill.co.uk/
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline onethumb
« Reply #9 on: June 18, 2017, 11:47:15 PM »
Mick
And me. They were tip top.
