Author Topic: Oil tank getting hot..  (Read 712 times)
Offline El__burro
« on: June 14, 2017, 09:53:54 PM »
Good day,  i am trying to understand if it is normal for the oil tank getting hot after a few miles ride.
I have no plastic cover.. should i get one?
el__burro
Sent from my SM-G935F using Tapatalk
Re: Oil tank getting hot..
« Reply #1 on: June 14, 2017, 10:03:06 PM »
Yep, entirely normal and with a good run it'll get to about 90degrees as that's what the oil will run at, ish.
Offline steff750
  • THE POWER OF DREAMS
« Reply #2 on: June 14, 2017, 10:03:20 PM »
 ;) yes its normal no worries ,and get a cover you wont notice the heat
« Reply #3 on: June 14, 2017, 10:40:34 PM »
  its good to get the oil and engine hot,it removes moisture and condensation caused by short runs .
 I always try to ride at least 10 miles each ride,and many more at times !!
Offline El__burro
« Reply #4 on: June 15, 2017, 08:37:53 PM »
Thanks, i am planning to either get a plastic cover or create some sort of shield..
el__burro
