Author Topic: Wiring bits and bobs UK supplier help??  (Read 1264 times)
Offline Wenman
  • First build done cb550 supersport
« on: June 30, 2017, 09:42:51 AM »
Hi everyone,
I am about to clean up the wiring loom having had some charging issues.
I need to know what gauge wire is used on the CB550 and what size connectors etc would be best.
I would like to replace the bullet connectors with sleeved spade connectors.. what size would be best?
Also if anyone knows of a good UK supplier that would be handy... I need a pic 'n' mix place where I can buy bits without having to buy a kit with a million things I don't need.
thanks guys
Al
If at first you don't succeed.. hit it with something!
Offline petermigreen
Re: Wiring bits and bobs UK supplier help??
« Reply #1 on: June 30, 2017, 09:58:27 AM »
I use these two regularly
http://www.vehicle-wiring-products.eu
https://www.autoelectricsupplies.co.uk
Can't remember the gauge of the wire but it needs to be good for 15A.
Unless it's part of the starter circuit which needs to be much heavier.
Peter
« Last Edit: June 30, 2017, 10:00:55 AM by petermigreen »
Online AshimotoK0
« Reply #2 on: June 30, 2017, 10:53:35 AM »
You need 3.5mm bullets (not 3.9)  and they are only available from the USA or China when / last bought some. I will try to dig out the info.
http://www.ebay.co.uk/itm/120-Pcs-3-5mm-Motorcycle-Brass-Bullet-Male-Female-Wire-Connector-With-Covers-/192117418954?hash=item2cbb172bca:g:fOEAAOSw6DtYVPYT
VintageConnections in the USA sell a whole range but last time returned my PayPal money saying they no longer ship to UK but told me their suppliers who do deal with UK. They also sell the Hitachi style multi-pin 6.3 blade connectors and glossy, soft black or silver sleeving and loom tape.I will try to dig out the info. tonight.
Offline mike the bike
« Reply #3 on: June 30, 2017, 11:23:05 AM »
The 6 way 6.3mm connector blocks take up too much space in the headlamp shell and that's pushed for space as it is.
I used the 3.9mm bullets from Vehicle Wiring Products and have been OK 👌
Online AshimotoK0
« Reply #4 on: June 30, 2017, 11:28:20 AM »
They are OK as long as you don't use with the existing mating Honda bullets /receptacles. Not sure but I think CB72/77 are the larger size. If you don't need standard Deutsch connectors are the dogs B  http://www.deutschconnector.com/products/deutsch_connectors/deutsch_dt_series_connectors/
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #5 on: June 30, 2017, 05:53:49 PM »
I buy cable and some bullet/socket (3.9mm) connectors from vehicle wiring products. As Ash says they should be (3.5mm) but for the extra cost why not replace the opposite connector.
Also, vehicle wiring do not stock the 6.3mm Honda OE block connectors (as image), and from experience they are difficult to find.
PM me if you need 1/2
Alan
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
Online AshimotoK0
« Reply #6 on: June 30, 2017, 10:21:18 PM »
This is the place I use in the States ... They even sell the soft silver coloured sleeving used on 60's Hondas.
http://cycleterminal.com/
The main thing I can't find anywhere though is the round brown multiway connectors used on CB750K0 / CB250/350K ignition switch.
Offline Wenman
« Reply #7 on: June 30, 2017, 10:50:12 PM »
Thanks all.. Ive ordered some bits and bobs!
Time to clean this loom up and get back on the road!!
al
« Reply #8 on: June 30, 2017, 10:55:43 PM »
If you have a dishwasher,  chuck the loom in on a cycle.  It comes up like new.
Offline Wenman
« Reply #9 on: July 01, 2017, 07:03:40 AM »
Thanks Mike.. it's already in the washing machine!
Online AshimotoK0
« Reply #10 on: July 01, 2017, 07:58:30 AM »
What I do is then ultrasonically clean the ends is distilled water of the connectors to remover any trace of dishwasher salt, if you get salt in those connectors and the crimped wire ends ... then expect trouble further down the line.
« Reply #11 on: July 01, 2017, 10:49:54 AM »
Alan. I may have missed all your posts, do you have a CB550K or CB500F. The 'K' has a 5 wire safety switch as the 'F' as a 2 wire safety switch.
If it's the 'K' 5 wire switch (red connector as image) is it still operating?
Alan
Current bikes:-
Offline Wenman
« Reply #12 on: July 01, 2017, 05:54:36 PM »
Alan
Big Al,
I'm sure it's the 5 wire safety plug but it def ain't red??
Still working mind!👌
Al
« Reply #13 on: July 01, 2017, 06:58:48 PM »
Thanks for the reply Al,  I've been helping a friend with his CB550K3, his also has no 5 wire red connector for the safety switch.
The Clymer manual M332 (as image) shows the 5 wire/switch, but I have now found out that it only applies to the CB550 K0 & K1. All versions thereafter are 2 wire.
Thanks again
Alan
Current bikes:-
