Author Topic: Advice on engine problem  (Read 1837 times)
Offline sprinta
« on: July 06, 2017, 03:29:41 PM »
Have just bought a 73 CB750K2. It is one that has had a complete engine rebuild, re-bore, chains, guides etc and had completed around 350 miles before purchase.
Over the weekend did around 200 miles, nothing exceptional to note.
Took it out on Tues and did notice a bit of smoke and a slight engine oily smell on startup but did not identify from which pot(s) it was from?
After around 30/40 miles it started sputtering and thought it need to go onto reserve. However, it did not improve so stopped to have an inspection. No 2 downpipe was only lukewarm so clearly a problem with No 2 pot, bugger.
Limmped home on three and removed the plugs, see photos, No 1 on left. No 2 totally black and carbonated. No's 1 and 4 OK but No 3 slightly black.
Decided to check the compression. No's 1 and 4 around 150 psi but No's 2 and 3 around 135 psi. All just within 10% of each other but with my understanding that they should all be within 150 to 170 psi No's 2 and 3 are low? See photos.
No spark at all from the No 2 plug so got a replacement which I fitted today.
On startup a lot of smoke from No 2 but all 4 pots now firing. Went for a ride and stopped after 10 miles or so. Now only slight smoke from No 2 so hoping that it was just a build up that was now burning off following the 30/40 ride home with No 2 not firing?
Anyway, carried on as the bike seemed OK so was hoping that it may have just been a duff plug? Stopped again after 20 miles and No 2 now practically free from smoke.
However, after around 30 miles it started to splutter again and was now firing intermittently on No 2.
Got home and removed the plugs again. No's 1 and 4 still OK but No 2 black again and No 3 also blacker than one would expect, see photo.
Is it a piston/ring/seal/valve/guide problem and excessive oil or is it carburetion or possibly a coil problem as both 2 and 3 are on the same coil?
Any advice would be appreciated.
Andy
« Last Edit: July 06, 2017, 03:33:51 PM by sprinta »
Offline adriangsmith
Re: Advice on engine problem
« Reply #1 on: July 06, 2017, 03:55:34 PM »
Looks like a carb setup issue to me.
Running way too rich.
Are you running the standard airbox or pods?
Had it on mine a couple of times until run in.
Once was a stuck float valve,another a blocked idle jet and the other time was because the plugs soot up and won't spark through the carbon buildup.
Could also be plug caps or coils.
Also at only 350 miles it's not yet run in.
Needs 500 - 750 miles for everything to be settled in properly.
Once at 750 miles make sure you do an oil change.
« Last Edit: July 06, 2017, 03:57:27 PM by adriangsmith »
Triumph Thruxton 2004
Honda CB750F1 1976
« Reply #2 on: July 06, 2017, 04:09:55 PM »
As you've got commonality with ignition on 2 and 3, as you point out,  I'd look at that to eliminate it first of all and before you chase carburation to any degree.
This is partly mirrored in the recent post by RGP on his restored 750 with a spark drop out causing very similar effects, worth a read through to see discussion.
Also,  a quick check up the carb throats to make sure the choke flaps are being fully removed from airflow when retracted.
Offline sprinta
« Reply #3 on: July 06, 2017, 05:04:01 PM »
Thanks for the reply.
Using std air box with new filter, so that should not be causing any restrictions? Have managed to removed the main and pilot jets without removing the carbs and the jets, at least, are all clear.
Will check the plug caps for 5K resistance?
Offline sprinta
« Reply #4 on: July 06, 2017, 05:09:01 PM »
Certainly hoping that it a carb/coil problem and not engine issue?
Don't have another coil to try but will check the various resistances including the plug caps to see if that pick anything up?
Has electronic ignition fitted but don't see that as an issue as No 1 and 4 seem OK?
Good point on the carb choke flaps.
Do you have a link to the post you were referring to?
Offline RGP750
« Reply #5 on: July 06, 2017, 07:07:05 PM »
Here you go.
Hope it's all yours is .
Good luck
http://www.sohc.co.uk/index.php/topic,13165.0.html
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
« Reply #6 on: July 06, 2017, 07:23:35 PM »
Try swapping 2 and 3 plug leads.  As they fire the same time it won't make any difference to the running.  If the problem migrates to no. 3, then it's a HT problem.
« Reply #7 on: July 06, 2017, 08:35:29 PM »
Thanks Rich,  I was in too much of a rush to look for it properly.
Something with these fours generally is that if they're built well then there's not much that really goes wrong with them, they are very reliable usually.
Sprinta,  it may take a little sorting through to properly debug each example but each little bit of attention should gradually move it forward to running really well.
Also if it's been bored,  honed, glaze busted it that rebuild with new rings,  then you'd expect the compression readings to be improving still at this point and up until closer to a thousand miles. You may be getting a discrepancy with the unburnt petrol washing oil off the bores prior to testing at the moment so any correction of running and firing reliably should give you a better look at the compressions after a decent runout.
Offline sprinta
« Reply #8 on: July 06, 2017, 10:13:17 PM »
Here you go.
Good luck
Thanks. Interesting read with several points for me to check.
Offline sprinta
« Reply #9 on: July 06, 2017, 10:29:40 PM »
Thanks for all the replies and suggestions.
All new NGK plug caps which all give a reading of around 5K ohms
Secondary coil resistances both around 15K ohms. Have not tested primary resistances yet.
My initial worry was that it was a guide seal or piston/ring problem when I first looked at the No 2 plug, 2nd photo. But at this stage that plug had done around 300 miles and around 30/40 miles not firing. Following the plug change it did smoke but cleared up after 10/20 miles before fouling again at around 30 miles.
The photo of the No 2 plug this time shows a less oily deposits and more black carbon as it was firing intermittently so at this stage I am still at  a bit of a loss as to the likely cause?
Will check the primary resistance of the coils and then swap the N0 2 and 3 ht plugs/leads over and see if the transfers the problem?
Also need to check the valve clearances as they may be a bit tight on No 2 and 3 resulting the slightly lower compression?
As previously advised all the main and pilot jets are clear. Yes I did have the throttles fully open and the tests were done with the engine up to full operating temp, still got the bl**dy burns trying to screw the hoses into the plug holes!
« Last Edit: July 06, 2017, 10:32:51 PM by sprinta »
Offline Dazza215
« Reply #10 on: July 07, 2017, 09:42:25 AM »
Check your points as well as they are common on 2 and 3, 1 and 4.
I dont ride a bike to add days to my life. I ride to add life to my days.
Offline petermigreen
« Reply #11 on: July 07, 2017, 10:27:55 AM »
Same for condensers
Offline sprinta
« Reply #12 on: July 07, 2017, 01:48:13 PM »
The bike has electronic ignition fitted, so points and condensers are out of picture.
I have receipts showing that gen head gasket was used.
I note that main jets are 110 and pilots 40. All air screws around 1/2 turn out? UK K2.
« Last Edit: July 07, 2017, 01:51:12 PM by sprinta »
Offline sprinta
« Reply #13 on: July 07, 2017, 03:02:25 PM »
Primary resistance of coil both 4.8 ohms.
Swapped the HT leads of No's 2 and 3 over and did around 50 miles. The black sooty plug has now moved No 3, see photos, No 4 on left. So is that indicating that there is something wrong with that particular ht lead?
With No 2 now showing a more normal colour can I now rule out seal or piston/ring as being the cause?
« Reply #14 on: July 07, 2017, 03:50:56 PM »
Start it tonight in a real dark place and have a good look at that HT lead to see if it's tracking out to earth anywhere, it's one of the quickest ways to find a leak in HT systems. You may have to take the tank off to get a good view of the first parts of the leads.
Sounds like progress though as you've got it to move around and so giving you a direction.
