Author Topic: Oil leak  (Read 678 times)
Offline Glynnrg
Oil leak
« on: July 08, 2017, 04:08:36 PM »
Seem to have oil weeping from this nut on the back of my 550f can anyone tell me what it does?
Re: Oil leak
« Reply #1 on: July 08, 2017, 04:35:50 PM »
It's your camchain tensioner.
Offline Glynnrg
Re: Oil leak
« Reply #2 on: July 08, 2017, 04:58:48 PM »
Offline Glynnrg
Re: Oil leak
« Reply #3 on: July 08, 2017, 07:14:26 PM »
Not good then as it doesn't seem to tighten just spins round and round
Re: Oil leak
« Reply #4 on: July 08, 2017, 07:40:35 PM »
Try a replacement nut first before getting too panicky, seem to remember it's a normal M6 nut.
Offline Glynnrg
Re: Oil leak
« Reply #5 on: July 08, 2017, 07:46:04 PM »
It's not the nut spinning it's the whole bolt  :'(
Re: Oil leak
« Reply #6 on: July 08, 2017, 08:11:58 PM »
Ah, that is not good news, head off job to replace it, and not a cheap part to buy either. One bonus is you can do it with the engine in the frame.
Re: Oil leak
« Reply #7 on: July 08, 2017, 08:28:01 PM »
If that nut is spinning your cam chain tensioner is not working and bad wear results, usually caused by a previous numpty using a screwdriver in the slot to try and force the tensioner to work---its only there to position the tensioner on rebuild.
Sometimes the tensioner mechanism can be fixed as long as the teeth are not broken
Offline Glynnrg
Re: Oil leak
« Reply #8 on: July 08, 2017, 09:14:20 PM »
Thanks for the advice even tho you are bearers of bad news
