Author Topic: CB550K3 PD46A Carb problems  (Read 547 times)
Offline davidrsmith
« on: July 09, 2017, 06:43:42 PM »
Hi
I have now put the carbs back on the bike, from the advice given before I have replaced the main jets, the slow running jets and the float valves. I haven't replaced the needle valves though.
I set the float heights to 14mm as described in a PD46A overhaul document I found on line.
I started the bike on the choke and over the next minute or closed the choke and the bike ticked over at about 1000 rpm. When I opened the throttle the bike cut out. I restarted the bike (without the choke) and it raced up to 3800 rpm and stayed there. Everytime I started the bike after this the engine raced up to 3800 rpm and stayed there.
I have the carb to air filter connector attached but no air filter.
Can anyone give me any advice before I rip the carbs out and strip them down again?
Many thanks
Dave
Offline petermigreen
Re: CB550K3 PD46A Carb problems
« Reply #1 on: July 09, 2017, 06:49:25 PM »
Have you tried adjusting the idle speed with the idle screw?
Offline davidrsmith
« Reply #2 on: July 09, 2017, 07:32:25 PM »
Hi,
Yes, the throttle idle screw for all four carbs is backed right off until it has no effect.
The individual idle screws are set to one and a half turns.
I suspect there are two problems here, but any ideas would be welcome.
Dave
« Reply #3 on: July 09, 2017, 08:12:12 PM »
Have you got any slack in the throttle cables?
Do the carb's have the choke cable going to handlebar, if so,  again is there slack there when closed?
« Reply #4 on: July 10, 2017, 07:25:59 AM »
If you set the slide heights to a slide that was slightly open they wont close properly
