Author Topic: Rust in Tank  (Read 1138 times)
Offline boilermaker1
Rust in Tank
« on: July 20, 2017, 11:40:33 PM »
Hi all
I have some very mild patches of rust on the inside of  my petrol tank.
What is the best cure for this ?
Thanks in advance
Offline sgd37
Re: Rust in Tank
« Reply #1 on: July 21, 2017, 02:07:59 AM »
I treated my badly rusted tank with phosphoric acid. About 45% concentration swish around until there is no more rust (about 5-10 min), empty, wash out remaining acid with coca cola (yes I'm serious, it's the only way I found to stop it from flash rusting), then put in methelated  spirits (300ml) to absorb all moisture, finally wash out with petrol. It should leave a rust resistant iron phosphate layer. Mine has had this treatment and has remained rust free since. Also be careful that the acid will attack the petcock so don't leave it in too long or take it off completely.
If you can reach the rust then coke and rub with tin foil works well due to the phosphoric acid in the coke.
Offline Clunker
Re: Rust in Tank
« Reply #2 on: July 21, 2017, 01:46:36 PM »
That sounds like good advice sgd37 but I'm wondering does the acid damage paint?
Usually sat on a bucket polishing my nuts.
Offline sgd37
Re: Rust in Tank
« Reply #3 on: July 21, 2017, 02:11:15 PM »
I had a few spillages while doing mine and the paint didn't look affected at all. Obviously I didn't leave it on there but washed it off with water with some bicarbonate soda mixed in. Phosphoric acid is pretty safe as long as you take sensible precautions. It is only stuff with magnesium in it that is at risk.
Offline philgresty
Re: Rust in Tank
« Reply #4 on: July 21, 2017, 02:11:36 PM »
Fill it full of vinegar and leave for atleast a few days
Offline Colonial-Clive (yindi)
  • Colonial_clive
Re: Rust in Tank
« Reply #5 on: July 21, 2017, 02:48:03 PM »
I used brick/patio cleaner (hydrochloric acid) 1gallon for about £10 from your local builders merchant. Pour in leave for 15 mins empty back into container repeat if needed. Then rinse with water and then with petrol. Worked a treat on mine.
Offline gtmdriver
Re: Rust in Tank
« Reply #6 on: July 22, 2017, 03:31:17 PM »
Use Deox-C from Bilt Hamber.
Does not affect paint or any other material. Dissolves rust but leaves good steel unaffected. Non-toxic and biodegradable.
It will clean the interior of the tank down to clean steel.
http://www.bilthamber.com/deox-c
Offline Clunker
Re: Rust in Tank
« Reply #7 on: July 22, 2017, 06:49:34 PM »
I followed the link and this does sound like a good product according to the reviews but I was wondering if you have to treat the inside of the tank afterwards to stop flash rusting?
Re: Rust in Tank
« Reply #8 on: July 22, 2017, 10:10:35 PM »
We have a heated tank of  it at work .. it's good but you may be better with phosphoric acid that leaves an anti rust phosphate coating on the metal. DeoxC is a chelating agent much like oxalic acid but non toxic. I think most tank sealing kits use phosphoric acid treatment prior to application of the coating.
Offline gtmdriver
Re: Rust in Tank
« Reply #9 on: July 22, 2017, 11:53:13 PM »
Deox-C is far more efficient than phosphoric acid at actually removing rust but if you want a protective coating on the inner surface you could always give it a swill round with a phosphating agent after removing all the rust with Deox.
POR15 Metal Prep works well.
Re: Rust in Tank
« Reply #10 on: July 23, 2017, 09:47:17 AM »
I reckon the best method of rust removal is mechanical. Small sharp metal things shaken around using cement mixer or  big tumble  drier etc with tank suitably protected of course. Watch Deox C with chrome .. if you leave a long time, the Chrome starts  to blister and strip....  :(  DAMHIKT ! Also seem to remember it blackens the likes of some gear components etc.
