Author Topic: cb550 first attempt - restore and modernise  (Read 3861 times)
Re: cb550 first attempt - restore and modernise
« Reply #30 on: October 19, 2017, 07:47:14 PM »
For a guy with “no mechanical skills” you look to be doing fantastically well!  Not too many people would be prepared to dig that deep into a motor without any prior knowledge... I would also expect the bottom end to be ok but as you can get your fingers on the con-rods you should be able to get a good feel for how worn or not it is before you compkete the rebuild, unless you already have done.... good luck anyway. Looks like a nice project!
Offline Rozabikes Tim
« Reply #31 on: October 19, 2017, 10:14:53 PM »
Its looking good Aled.  Rapid progress is being made, you'll have it on the road next weekend at the rate you are going :o
I like the idea of having the bike bench on castors, simple and effective in a small garage.
Keep the photos coming.
Re engine stand, got me thinking too. Is this what you have?
http://www.ebay.co.uk/itm/Heavy-Duty-Swivel-Transmission-Gearbox-Engine-Mount-Support-Stand-1000-lbs-450kg-/282582463347?epid=1039473391&hash=item41cb3a3373:g:eHIAAOSw-QZZzMbf
Was it easy to adapt to bike engine etc....?
