Try our new info resource - "Aladdin's Cave" (Main menu)Just added a separate link to Ash's Dropbox thread (shortcut)
Quote from: Greebo on August 06, 2017, 10:24:19 AMEmily Ratajkowski is that her that use to play in Coronation Street ?.. thought you had better taste Mark. stick with the MV... She'd be more reliable, and probably "Go" better than anything shitalian! Sent from my X6pro using Tapatalk
Quote from: hairygit on August 06, 2017, 10:40:51 AMQuote from: Greebo on August 06, 2017, 10:24:19 AMEmily Ratajkowski is that her that use to play in Coronation Street ?.. thought you had better taste Mark. stick with the MV... She'd be more reliable, and probably "Go" better than anything shitalian! Sent from my X6pro using TapatalkThought I'd flush you out with the Italian bit HG 😄
Quote from: MarkCR750 on August 06, 2017, 04:36:42 PMQuote from: hairygit on August 06, 2017, 10:40:51 AMQuote from: Greebo on August 06, 2017, 10:24:19 AMEmily Ratajkowski is that her that use to play in Coronation Street ?.. thought you had better taste Mark. stick with the MV... She'd be more reliable, and probably "Go" better than anything shitalian! Sent from my X6pro using TapatalkThought I'd flush you out with the Italian bit HG 😄Problem is, you lunatics are like trying to stop a toddler playing in a cat litter tray, you won't learn until you end up with it in your hands, and probably in your mouth too! Then whingeing about the taste! Sent from my X6pro using Tapatalk
If you have the stuff to try it with conventional points, give that a try before spending loads when it may not be the issue, or maybe there are shitalian components in the electronic system! (Couldn't resist that!) Sent from my X6pro using Tapatalk
Take a spare plug out with you and if it does it again you can check for a spark there and then on any of the cylinders to see if the ignition isn't working or it's something else.My dad's friend always just put his finger in the plug caps to check for sparks years ago, proper old mechanic's fingers he had.
Electronic, the original Piranha set up that came with the donor bike, it must be 20+ years old as the previous owner took it off the road in 1995, so you could be onto something there H, I believe that the Newtronic set up is pretty much the same as the old Piranha so maybe it's time to invest in a new one.
