Author Topic: Plugs and caps  (Read 937 times)
Offline Ashdowner
Plugs and caps
« on: August 19, 2017, 07:29:39 AM »
My CB550K3 has electronic ignition, DR7ES plugs, but also has 5ohm resistor plug caps? Is that right or should the caps be non-resistor? Does it actually make any difference?
CB550K3, CB550K1, Yamaha Midnight Star, and CA77 in 2473 pieces (at the last count)
Re: Plugs and caps
« Reply #1 on: August 19, 2017, 07:48:13 AM »
I have been informed that all new plug caps are fitted with a resistor so, you need to fit spark plugs with non resistor, D7EA or D8EA work fine with me.
« Last Edit: August 19, 2017, 09:06:57 AM by Trigger »
Re: Plugs and caps
« Reply #2 on: August 19, 2017, 08:32:57 AM »
Quote
What's the history of your bike? What model (for what market?)? What brand plugcaps do you have? Are they the original ones?
Re: Plugs and caps
« Reply #3 on: August 19, 2017, 08:39:37 AM »
Fit non resistor plugs as Graham suggests. Cheapest fix as well...
Offline Seabeowner
Re: Plugs and caps
« Reply #4 on: August 19, 2017, 09:42:59 AM »
Always causes discussion this subject. A Delta hinted, different markets (especially earlier models) sported different combinations caps and plugs. Possibly because of regs about RFI. And DSS among others sells DR7ES for all 500/550s I think. (just below the 5k caps). Techis get into length of spark duration/ fuel consumption, starting, plug fouling and the like. The subject always comes up when ignition probs are suspected.
I've used both R caps with and without R plugs and never had a problem. (with electronic ignition and original). But if D7ES are cheaper, get em.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Re: Plugs and caps
« Reply #5 on: August 19, 2017, 12:23:56 PM »
Maybe the 550's are less sensitive to this, who knows. I know from bitter experience chasing my tail on 750's that I always now use resistor caps and non resistor plugs.
Re: Plugs and caps
« Reply #6 on: August 19, 2017, 12:37:08 PM »
Indeed, Mr Sliver does sell the DR8ESL plugs for the 500, the 550 and the 400. I made the mistake of buying these plugs from him and started having problems with my 400. As soon as I ditched the resisted plugs and fitted D8EA's, problem solved.
Offline Norniron
Re: Plugs and caps
« Reply #7 on: August 19, 2017, 12:45:09 PM »
I always thought my 400 was just old and tired but since i started using non resister plugs,its now purring like a kitten.
Thanks Trigg
1977 400 cafe
1972 500/4
2013 triumph STR675
Re: Plugs and caps
« Reply #8 on: August 19, 2017, 12:51:31 PM »
Thanks Trigg
No worries mate, I will add it to your bill  ;D ;D ;D And before anyone asks, Norniron is running a electric ignition but, it works the same with points  ;)
Re: Plugs and caps
« Reply #9 on: August 19, 2017, 12:55:51 PM »
Thanks Trigg
That is one loud kitten  ;D ;D
Offline Norniron
Re: Plugs and caps
« Reply #10 on: August 19, 2017, 01:09:42 PM »
I would load a video of it but can never figure out how😫😫
1977 400 cafe
1972 500/4
2013 triumph STR675
Re: Plugs and caps
« Reply #11 on: August 19, 2017, 01:18:43 PM »
I think you need to post the video on youtube, then post a link to it on here.
Offline Moorey
Re: Plugs and caps
« Reply #12 on: August 19, 2017, 06:11:31 PM »
Thanks Trigg
Who doesn't use a electric ignition. Don't see many hot plugs about these days.  ;) ;D
Re: Plugs and caps
« Reply #13 on: August 19, 2017, 09:04:29 PM »
Thanks Trigg
I have points on most of my bikes, except the CD250 U's where it was standard and the Thundercat.
Offline Moorey
Re: Plugs and caps
« Reply #14 on: August 19, 2017, 09:42:33 PM »
Thanks Trigg
Just humour all ignitions are electric even those with points.  ;)
