Author Topic: Fork seal - damper bolt removal?  (Read 2507 times)
Offline zebedee85
Re: Fork seal - damper bolt removal?
« Reply #30 on: September 01, 2017, 11:56:59 AM »
Well - the operation was a success, though now I'm getting some stiction. I was a bit over zealous with the fork oil quantity so letting them drain a bit might fix it.  No weeping though.
Offline zebedee85
« Reply #31 on: September 01, 2017, 10:37:01 PM »
Too much fork oil - removing approx 10cl both sides fixed stiction.
« Reply #32 on: September 02, 2017, 07:42:14 AM »
When you use the drain bolt, it will still leave oil in the tube so, keep a eye on the measurements  ;)
