Author Topic: Honda CB550 four K AWY 834S  (Read 9540 times)
Re: Honda CB550 four K AWY 834S
« Reply #75 on: July 28, 2020, 09:44:21 PM »
Yeah interesting channel, not just for info but mostly for the nice looking builds he does...👍
Offline rocker61
« Reply #76 on: July 31, 2020, 04:19:51 AM »
inspecting my coils and leads I found a cracked ngk spark cap, so have replaced this, I have noticed the ht cables have a external covering of some form, and these are shorter than the internal cables. I am presuming these covers provide strength and extra weather sealant? if so what are they/where do I find these, any help gratefully received
« Reply #77 on: July 31, 2020, 08:11:13 AM »
The closest I can find is 1mm wall, black,  silicone,  which is in fact superior property wise to the nitrile rubber Tec &N.D. used.
Choose ID to match the Honda stuff . IIRC it's about 8mm and the HT cable is 7mm. It's the HT cable which hardens and breaks .. quite often you can re-use the rubber sheathing after a good clean up.
https://www.ebay.co.uk/sch/m.html?_ssn=hilltopuk25&LH_PrefLoc=&_from=R40&_trksid=m570.l1313&_nkw=sleeve+silicone+black+id+&_sacat=0
« Last Edit: July 31, 2020, 08:15:04 AM by AshimotoK0 »
Offline rocker61
« Reply #78 on: August 01, 2020, 09:55:47 PM »
ashjmoto thanks for the info will look into this
