Author Topic: Spark Plugs and caps  (Read 1720 times)
Offline Valentinik
« on: September 06, 2017, 08:33:11 PM »
Re: Spark Plugs and caps
« Reply #1 on: September 06, 2017, 08:43:01 PM »
Use plugs WITHOUT resistors.
Offline Valentinik
« Reply #2 on: September 06, 2017, 08:44:00 PM »
Thanks, i thought that may be the case. What model plugs are recommend?
« Reply #3 on: September 06, 2017, 08:44:06 PM »
Plugs without resistors if your caps are resisted.
« Reply #4 on: September 06, 2017, 08:45:16 PM »
I use D8EA's
« Reply #5 on: September 06, 2017, 08:47:57 PM »
Whatever is recommended for a 550, but without the R in it ie book says DR8ES, USE  D8ES
Offline Valentinik
« Reply #6 on: September 06, 2017, 08:56:59 PM »
Thanks both, from looking at the parts list the D7ES is listed.
I presume the D8 is a cooler running plug? What would the advantage/disadvantage of the cooler plug be?
« Reply #7 on: September 06, 2017, 08:59:23 PM »
No idea but it's what we have on the shelf. I now have them fitted to my CB400 and CB550
« Reply #8 on: September 06, 2017, 09:25:21 PM »
I gave D8ES as an example as I didn't have the application list to hand. Cooler running plugs are for sustained high rpm use, higher the number the cooler the plug. If in traffic stop/start most of the time go one grade hotter (lower number), also useful if worn engine fouling plugs.
Offline Green1
« Reply #9 on: September 06, 2017, 09:34:55 PM »
My 550 With electronic ignition had DR7ES fitted but soon failed them.
I replaced them with DR8ES and its been fine since I do very little town use.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Valentinik
« Reply #10 on: September 06, 2017, 09:37:39 PM »
Thanks everyone for the help. I know what i need to get now  :)
Mike
Offline Green1
« Reply #11 on: September 06, 2017, 09:40:24 PM »
meant to say D7ES and D8ES
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #12 on: September 07, 2017, 07:59:50 AM »
Originally in the book it was D7ES which wasn't a particular good plug. Dealers in Holland considered it OK for the break-in period but advised later to use newcomer D8ES-L if you would ride the highways. The D8ES probably would have been to cold. You may say the D8ES-L with its tip that protruded just a tiny bit further, was in between the 7 and 8. Honda France advised them for the CB500/550 and called them auto-nettoyante (selfcleaning). BTW, the D8ES-L was/is used on a wide variety of bikes. I had them in my CB500 on all my travels in Europe often at maintained high speeds. I wouldn't have felt comfortable with the 7, not when you, what happened more than once, were late to switch to reserve... So it depends on your riding, but if the D8EA is the new name for the D8ES-L, it's a good choice. If you don't cruise over 5000 rpm, you may consider the 7EA.
« Last Edit: September 07, 2017, 08:06:31 AM by deltarider »
« Reply #13 on: September 07, 2017, 04:47:28 PM »
Way back when i switched to D7EV on a 500 and it started noticably better , did more to the gallon and picked up cleaner/quicker. unfortunately NGK have stopped making them now but Denso do an equivalent that i never tried
« Reply #14 on: September 08, 2017, 10:03:50 AM »
Quote
The only Denso that is not really an equivalent is the iridium plug IX22 which is a later development. So far I've read no recommendations for our bikes.
